  4. Need help
Need help
167 Posts 11 Posters 102.0k Views
    @terry-tz said in Need help:
    @vtrn_raptor no no no we don't mean buying original exhaust ect we mean to put the carb and a few other bits if you have them back to standard and honestly we understand you don't have a clue at the end of the day it's your bike and your choice but you would really benefit from doing it your self and save money at the same time really it easy just looks hard pal just throw some pics up mate it could be an easy fix you just don't know how it works yet
    Is he really saving any money though? I mean if he's spent 2.5k on it and still not solved it, then obviously he's just throwing money away.
    Second that though, most shops are going to return it to stock trim to fix it.
    I can't see it being anything particularly difficult.
    terry.tzT
    terry.tzT
    terry.tz
    @calum the bike runs sounds like he been playing with it so it not chewing itself to bits on the inside considering he been redlining on a stand so the bike should be an easy fix in my opinion 2.5k tho @vtrn_raptor I could buy a few dt125r's for that just make a new thread call it the 2.5k black hole and start from scratch give us the bike details in the description ie year, model and any mods don't focus on a symptom yet just get some pics up
    • NottsbikerN
      NottsbikerN
      Could be a conflict between old generators and new CDI's (for example) but with that amount of money being spent on it chances are its now something relatively simple
      I do however appreciate how frustrating these problems can be at time and how you want to murder someone when you've taken a carb apart 58 times 😉
      • V
        V
        vtrn_raptor
        Just done a compression test and it's at 100psi is that low ?
        • V
          V
          vtrn_raptor
          And the spark plug is black was a brand new one
          CalumC terry.tzT 2 Replies Last reply
          • V vtrn_raptor
            @vtrn_raptor Sounds like it's running rich. Is it sooty? Could be too much oil.
            Two strokes don't have too much compression.
            • V
              V
              vtrn_raptor
              I'll take a photo now
              • V vtrn_raptor
                terry.tzT
                terry.tzT
                terry.tz
                @vtrn_raptor really start from scratch your only confusing your self more it does sound like your running rich like @Calum said but I would not say that as you have still not put a picture of the plug up or taken a video and it could and most likely is too much fuel and that's why I said to run the bike for 10 sec's and take a picture as your descriptions are bad but considering that your at least trying I will tell and show you the differents alt text
                • terry.tzT
                  terry.tzT
                  terry.tz
                  • V
                    V
                    vtrn_raptor
                    terry.tzT 1 Reply Last reply
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      the top one is a plug with too much oil
                      the bottom one is too much fuel
                      which one is your closest too
                      • V vtrn_raptor
                        terry.tzT
                        terry.tzT
                        terry.tz
                        @vtrn_raptor I can't see the picture very well but yes that looks like a plug from too much fuel wet
                        • V
                          V
                          vtrn_raptor
                          Do you use Instagram ? As could send you a video of what the bikes doing on their
                          • terry.tzT
                            terry.tzT
                            terry.tz
                            no can you not put them on youtube
                            • V
                              V
                              vtrn_raptor
                              https://youtu.be/n9OW-WKmC5U
                              • V
                                V
                                vtrn_raptor
                                It's like this while riding won't go past 20mph soon as I let of the throttle it dies
                                • V vtrn_raptor
                                  terry.tzT
                                  terry.tzT
                                  terry.tz
                                  @vtrn_raptor yey now people can help you and this could be a few things don't think you will have a hard time solving this one I personally think that is a fuel problem what is it like at idle and building up to 6k and can it be a pain to start sometimes
                                  whats it like on and off choke take your time to answer
                                  • F
                                    Will it start without choke?
                                      terry.tzT
                                      terry.tzT
                                      terry.tz
                                      watch the video from 9-10 seconds a few times is that me or did that flood it self
                                        That looks and sounds like it's overfueling to fook.
                                        Quick check, remove the snorkel, does it get better or worse. Restrict the airbox, does it get better.
                                          terry.tzT
                                          terry.tzT
                                          terry.tz
                                          @calum good call if you watch the vid closely it Boggs out at 2k ish
