  4. Need help
Need help
167 Posts 11 Posters 96.9k Views
  • NottsbikerN Offline
    NottsbikerN Offline
    I bet that the shop will also want to put it back to standard to get it running correctly. Ideally you want to use a two stroke tuner / specialist so that they understand the issue and can both diagnose and then solve it.
    Many shops these days might not have as much knowledge of two strokes as one was the norm 🙂
    • V vtrn_raptor
      I would do it myself but I literally have no clue what's wrong with it and don't have the money to put it back standard
      terry.tzT Offline
      terry.tzT Offline
      terry.tz
      @vtrn_raptor no no no we don't mean buying original exhaust ect we mean to put the carb and a few other bits if you have them back to standard and honestly we understand you don't have a clue at the end of the day it's your bike and your choice but you would really benefit from doing it your self and save money at the same time really it easy just looks hard pal just throw some pics up mate it could be an easy fix you just don't know how it works yet
      • terry.tzT terry.tz
        @terry-tz said in Need help:
        Is he really saving any money though? I mean if he's spent 2.5k on it and still not solved it, then obviously he's just throwing money away.
        Second that though, most shops are going to return it to stock trim to fix it.
        I can't see it being anything particularly difficult.
        terry.tzT 1 Reply Last reply
          terry.tzT Offline
          terry.tzT Offline
          terry.tz
          @calum the bike runs sounds like he been playing with it so it not chewing itself to bits on the inside considering he been redlining on a stand so the bike should be an easy fix in my opinion 2.5k tho @vtrn_raptor I could buy a few dt125r's for that just make a new thread call it the 2.5k black hole and start from scratch give us the bike details in the description ie year, model and any mods don't focus on a symptom yet just get some pics up
            NottsbikerN Offline
            Could be a conflict between old generators and new CDI's (for example) but with that amount of money being spent on it chances are its now something relatively simple
            I do however appreciate how frustrating these problems can be at time and how you want to murder someone when you've taken a carb apart 58 times 😉
            • V Offline
              V Offline
              vtrn_raptor
              Just done a compression test and it's at 100psi is that low ?
              • V Offline
                V Offline
                vtrn_raptor
                And the spark plug is black was a brand new one
                CalumC terry.tzT 2 Replies Last reply
                • V vtrn_raptor
                  @vtrn_raptor Sounds like it's running rich. Is it sooty? Could be too much oil.
                  Two strokes don't have too much compression.
                  • V Offline
                    V Offline
                    vtrn_raptor
                    I'll take a photo now
                    • V vtrn_raptor
                      terry.tzT Offline
                      terry.tzT Offline
                      terry.tz
                      @vtrn_raptor really start from scratch your only confusing your self more it does sound like your running rich like @Calum said but I would not say that as you have still not put a picture of the plug up or taken a video and it could and most likely is too much fuel and that's why I said to run the bike for 10 sec's and take a picture as your descriptions are bad but considering that your at least trying I will tell and show you the differents alt text
                      • terry.tzT Offline
                        terry.tzT Offline
                        terry.tz
                        • V Offline
                          V Offline
                          vtrn_raptor
                          • terry.tzT Offline
                            terry.tzT Offline
                            terry.tz
                            the top one is a plug with too much oil
                            the bottom one is too much fuel
                            which one is your closest too
                            • V vtrn_raptor
                              terry.tzT Offline
                              terry.tzT Offline
                              terry.tz
                              @vtrn_raptor I can't see the picture very well but yes that looks like a plug from too much fuel wet
                              • V Offline
                                V Offline
                                vtrn_raptor
                                Do you use Instagram ? As could send you a video of what the bikes doing on their
                                • terry.tzT Offline
                                  terry.tzT Offline
                                  terry.tz
                                  no can you not put them on youtube
                                  • V Offline
                                    V Offline
                                    vtrn_raptor
                                    https://youtu.be/n9OW-WKmC5U
                                    • V Offline
                                      V Offline
                                      vtrn_raptor
                                      It's like this while riding won't go past 20mph soon as I let of the throttle it dies
                                      • V vtrn_raptor
                                        terry.tzT Offline
                                        terry.tzT Offline
                                        terry.tz
                                        @vtrn_raptor yey now people can help you and this could be a few things don't think you will have a hard time solving this one I personally think that is a fuel problem what is it like at idle and building up to 6k and can it be a pain to start sometimes
                                        whats it like on and off choke take your time to answer
                                        • F Offline
                                          F Offline
                                          Will it start without choke?
