  4. Need help
Need help
167 Posts 11 Posters 102.0k Views
  • terry.tzT
    terry.tzT
    terry.tz
    no can you not put them on youtube
    • V
      V
      vtrn_raptor
      https://youtu.be/n9OW-WKmC5U
      • V
        V
        vtrn_raptor
        It's like this while riding won't go past 20mph soon as I let of the throttle it dies
        terry.tzT 1 Reply Last reply
        • V vtrn_raptor
          terry.tzT
          terry.tzT
          terry.tz
          @vtrn_raptor yey now people can help you and this could be a few things don't think you will have a hard time solving this one I personally think that is a fuel problem what is it like at idle and building up to 6k and can it be a pain to start sometimes
          whats it like on and off choke take your time to answer
          • F
            Will it start without choke?
              terry.tzT
              terry.tzT
              terry.tz
              watch the video from 9-10 seconds a few times is that me or did that flood it self
                That looks and sounds like it's overfueling to fook.
                Quick check, remove the snorkel, does it get better or worse. Restrict the airbox, does it get better.
                  terry.tzT
                  terry.tzT
                  terry.tz
                  @calum good call if you watch the vid closely it Boggs out at 2k ish
                  • V
                    V
                    vtrn_raptor
                    Idles fine until giving throttle will gradually build up to 6k and even past it but does what happens in the vid if you give it full throttle with choke on it dies instantly but will start with it on but have to turn it off usually starts first kick from cold I'll take the snorkel off in a sec and give it a go
                    F 1 Reply Last reply
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      what it idle at
                      • V
                        V
                        vtrn_raptor
                        Around 1.5-2k
                        • V vtrn_raptor
                          Around 1.5-2k
                          terry.tzT
                          terry.tzT
                          terry.tz
                          @vtrn_raptor that's high
                          • V vtrn_raptor
                            @vtrn_raptor so it does start without choke? I can't make sense of what you said mate.
                            If it starts from cold without choke then it's 100% too rich
                            • terry.tzT terry.tz
                              terry.tzT
                              terry.tzT
                              terry.tz
                              @terry-tz that's an easy fix don't worry about that yet
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @finnerz89 yes he is bad at describing lol but it seems that way
                                • V
                                  V
                                  vtrn_raptor
                                  I forgot to put the , lol and it starts with choke on but I have to take It off to keep it running
                                  terry.tzT CalumC 2 Replies Last reply
                                  • V vtrn_raptor
                                    terry.tzT
                                    terry.tzT
                                    terry.tz
                                    @vtrn_raptor he means will it start cold without choke but don't worry about that
                                    • V vtrn_raptor
                                      @vtrn_raptor Yeah that's normal mate.
                                      It needs choke to start. That's normal. My DT NEVER started without choke.
                                      Once it's warm you can take the choke off that's normal.
                                      It must be something to do with the stock carb, as I haven't had this issue with my VHSA.
                                      But yes, it will need choke to start. Then once its warm it'll go to die, you then take the choke off.
                                      What's the problem.
                                        What's the problem.
                                        terry.tzT
                                        terry.tzT
                                        terry.tz
                                        mine starts with no choke cold every time
                                        • V
                                          V
                                          vtrn_raptor
