  4. Need help
Need help
167 Posts 11 Posters 102.0k Views
    Will it start without choke?
    terry.tzT
    terry.tzT
    terry.tz
    watch the video from 9-10 seconds a few times is that me or did that flood it self
      That looks and sounds like it's overfueling to fook.
      Quick check, remove the snorkel, does it get better or worse. Restrict the airbox, does it get better.
      terry.tzT 1 Reply Last reply
        terry.tzT
        terry.tzT
        terry.tz
        @calum good call if you watch the vid closely it Boggs out at 2k ish
        • V
          V
          vtrn_raptor
          Idles fine until giving throttle will gradually build up to 6k and even past it but does what happens in the vid if you give it full throttle with choke on it dies instantly but will start with it on but have to turn it off usually starts first kick from cold I'll take the snorkel off in a sec and give it a go
          F 1 Reply Last reply
          • terry.tzT
            terry.tzT
            terry.tz
            what it idle at
            • V
              V
              vtrn_raptor
              Around 1.5-2k
              • V vtrn_raptor
                Around 1.5-2k
                terry.tzT
                terry.tzT
                terry.tz
                @vtrn_raptor that's high
                • V vtrn_raptor
                  @vtrn_raptor so it does start without choke? I can't make sense of what you said mate.
                  If it starts from cold without choke then it's 100% too rich
                  • terry.tzT terry.tz
                    terry.tzT
                    terry.tzT
                    terry.tz
                    @terry-tz that's an easy fix don't worry about that yet
                      terry.tzT
                      terry.tzT
                      terry.tz
                      @finnerz89 yes he is bad at describing lol but it seems that way
                      • V
                        V
                        vtrn_raptor
                        I forgot to put the , lol and it starts with choke on but I have to take It off to keep it running
                        terry.tzT CalumC 2 Replies Last reply
                        • V vtrn_raptor
                          terry.tzT
                          terry.tzT
                          terry.tz
                          @vtrn_raptor he means will it start cold without choke but don't worry about that
                          • V vtrn_raptor
                            @vtrn_raptor Yeah that's normal mate.
                            It needs choke to start. That's normal. My DT NEVER started without choke.
                            Once it's warm you can take the choke off that's normal.
                            It must be something to do with the stock carb, as I haven't had this issue with my VHSA.
                            But yes, it will need choke to start. Then once its warm it'll go to die, you then take the choke off.
                            What's the problem.
                              What's the problem.
                              terry.tzT
                              terry.tzT
                              terry.tz
                              mine starts with no choke cold every time
                              • V
                                V
                                vtrn_raptor
                                • V vtrn_raptor
                                  terry.tzT
                                  terry.tzT
                                  terry.tz
                                  #53
                                  @vtrn_raptor take the cover off the side of the filter
                                    terry.tzT
                                    terry.tzT
                                    terry.tz
                                    @terry-tz try hitting the band in second
                                    • terry.tzT
                                      terry.tzT
                                      terry.tz
                                      do you have a haynes manual for your bike
                                      • V
                                        V
                                        vtrn_raptor
                                        Yeah I have a Haynes mate I would ride it without the cover on but it's raining loads down here lol
                                        terry.tzT 2 Replies Last reply
                                        • V vtrn_raptor
                                          terry.tzT
                                          terry.tzT
                                          terry.tz
                                          @vtrn_raptor haha far enough it would be fine though bit of rain doesn't hurt
