  4. Need help
Need help
167 Posts 11 Posters 102.0k Views
  • terry.tzT
    terry.tzT
    terry.tz
    what it idle at
    • V
      V
      vtrn_raptor
      Around 1.5-2k
      terry.tzT 1 Reply Last reply
      • V vtrn_raptor
        Around 1.5-2k
        terry.tzT
        terry.tzT
        terry.tz
        @vtrn_raptor that's high
        • V vtrn_raptor
          Idles fine until giving throttle will gradually build up to 6k and even past it but does what happens in the vid if you give it full throttle with choke on it dies instantly but will start with it on but have to turn it off usually starts first kick from cold I'll take the snorkel off in a sec and give it a go
          @vtrn_raptor so it does start without choke? I can't make sense of what you said mate.
          If it starts from cold without choke then it's 100% too rich
          • terry.tzT terry.tz
            terry.tzT
            terry.tzT
            terry.tz
            @terry-tz that's an easy fix don't worry about that yet
              terry.tzT
              terry.tzT
              terry.tz
              @finnerz89 yes he is bad at describing lol but it seems that way
              • V
                V
                vtrn_raptor
                I forgot to put the , lol and it starts with choke on but I have to take It off to keep it running
                terry.tzT CalumC 2 Replies Last reply
                • V vtrn_raptor
                  terry.tzT
                  terry.tzT
                  terry.tz
                  @vtrn_raptor he means will it start cold without choke but don't worry about that
                  • V vtrn_raptor
                    @vtrn_raptor Yeah that's normal mate.
                    It needs choke to start. That's normal. My DT NEVER started without choke.
                    Once it's warm you can take the choke off that's normal.
                    It must be something to do with the stock carb, as I haven't had this issue with my VHSA.
                    But yes, it will need choke to start. Then once its warm it'll go to die, you then take the choke off.
                    What's the problem.
                      What's the problem.
                      terry.tzT
                      terry.tzT
                      terry.tz
                      mine starts with no choke cold every time
                      • V
                        V
                        vtrn_raptor
                        • V vtrn_raptor
                          terry.tzT
                          terry.tzT
                          terry.tz
                          #53
                          @vtrn_raptor take the cover off the side of the filter
                            terry.tzT
                            terry.tzT
                            terry.tz
                            @terry-tz try hitting the band in second
                            • terry.tzT
                              terry.tzT
                              terry.tz
                              do you have a haynes manual for your bike
                              • V
                                V
                                vtrn_raptor
                                Yeah I have a Haynes mate I would ride it without the cover on but it's raining loads down here lol
                                terry.tzT 2 Replies Last reply
                                • V vtrn_raptor
                                  terry.tzT
                                  terry.tzT
                                  terry.tz
                                  @vtrn_raptor haha far enough it would be fine though bit of rain doesn't hurt
                                  • V
                                    V
                                    vtrn_raptor
                                    I'm gunna take the pv cover of and rev it to see if it opens correctly as that could be the issue as was pinned before I got the cdi and put it back on the servo
                                    • V vtrn_raptor
                                      terry.tzT
                                      terry.tzT
                                      terry.tz
                                      @vtrn_raptor go to page 86 and read
                                      • V
                                        V
                                        vtrn_raptor
                                        Will do mate
                                        • terry.tzT
                                          terry.tzT
                                          terry.tz
                                          don't go playing with carb setting yet tho I must stress to you that you should take your time and do every thing methodically or you could end up going in circles with problems you created which is what it sounds like you were doing, to begin with,
                                          this could still be a few things ie needle jets throttle even fuel line so start from the top
