  4. Need help
Need help
167 Posts 11 Posters 99.0k Views
  • terry.tzT terry.tz
    @vtrn_raptor that's high
    terry.tzT
    terry.tzT
    terry.tz
    @terry-tz that's an easy fix don't worry about that yet
      @vtrn_raptor so it does start without choke? I can't make sense of what you said mate.
      If it starts from cold without choke then it's 100% too rich
      terry.tzT
      terry.tzT
      terry.tz
      @finnerz89 yes he is bad at describing lol but it seems that way
      • V
        V
        vtrn_raptor
        I forgot to put the , lol and it starts with choke on but I have to take It off to keep it running
        terry.tzT CalumC 2 Replies Last reply
        • V vtrn_raptor
          terry.tzT
          terry.tzT
          terry.tz
          @vtrn_raptor he means will it start cold without choke but don't worry about that
          • V vtrn_raptor
            @vtrn_raptor Yeah that's normal mate.
            It needs choke to start. That's normal. My DT NEVER started without choke.
            Once it's warm you can take the choke off that's normal.
            It must be something to do with the stock carb, as I haven't had this issue with my VHSA.
            But yes, it will need choke to start. Then once its warm it'll go to die, you then take the choke off.
            What's the problem.
            terry.tzT 1 Reply Last reply
              What's the problem.
              terry.tzT
              terry.tzT
              terry.tz
              mine starts with no choke cold every time
              • V
                V
                vtrn_raptor
                • V vtrn_raptor
                  terry.tzT
                  terry.tzT
                  terry.tz
                  #53
                  @vtrn_raptor take the cover off the side of the filter
                    terry.tzT
                    terry.tzT
                    terry.tz
                    @terry-tz try hitting the band in second
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      do you have a haynes manual for your bike
                      • V
                        V
                        vtrn_raptor
                        Yeah I have a Haynes mate I would ride it without the cover on but it's raining loads down here lol
                        terry.tzT 2 Replies Last reply
                        • V vtrn_raptor
                          terry.tzT
                          terry.tzT
                          terry.tz
                          @vtrn_raptor haha far enough it would be fine though bit of rain doesn't hurt
                          • V
                            V
                            vtrn_raptor
                            I'm gunna take the pv cover of and rev it to see if it opens correctly as that could be the issue as was pinned before I got the cdi and put it back on the servo
                            • V vtrn_raptor
                              terry.tzT
                              terry.tzT
                              terry.tz
                              @vtrn_raptor go to page 86 and read
                              • V
                                V
                                vtrn_raptor
                                Will do mate
                                • terry.tzT
                                  terry.tzT
                                  terry.tz
                                  don't go playing with carb setting yet tho I must stress to you that you should take your time and do every thing methodically or you could end up going in circles with problems you created which is what it sounds like you were doing, to begin with,
                                  this could still be a few things ie needle jets throttle even fuel line so start from the top
                                  • V
                                    V
                                    vtrn_raptor
                                    Is it possible that my exhaust is filled with something as reading this page says about Miss firing could be down to exhaust spark plug or air filter
                                    • V
                                      V
                                      vtrn_raptor
                                      Or could this isue be down to stale petrol as it's probably been sat in the bike for 2-4 months
                                      F 1 Reply Last reply
                                      • V vtrn_raptor
                                        @vtrn_raptor stale fuel certainly won't be helping. I suggest you get some fresh in there
                                        • terry.tzT
                                          terry.tzT
                                          terry.tz
                                          for instance my brothers cbr 600f just stopped running when we were going out one day I started taking the carb off and seen a fuel pump and the carbs still got cleaned but it was the fuel pump so didn't even have to be cleaned they were minging anyways though the point is start from the top if I had checked the pump, to begin with, time would not have been wasted if fact I would have told him don't worry the bike would be fine without it there for extra fuel at really high rpm and just taken it out at the side of the road that day and we would have had a good day out
