Need help
@vtrn_raptor Yeah that's normal mate.
It needs choke to start. That's normal. My DT NEVER started without choke.
Once it's warm you can take the choke off that's normal.
It must be something to do with the stock carb, as I haven't had this issue with my VHSA.
But yes, it will need choke to start. Then once its warm it'll go to die, you then take the choke off.
What's the problem.
@vtrn_raptor take the cover off the side of the filter
Yeah I have a Haynes mate I would ride it without the cover on but it's raining loads down here lol
@vtrn_raptor haha far enough it would be fine though bit of rain doesn't hurt
I'm gunna take the pv cover of and rev it to see if it opens correctly as that could be the issue as was pinned before I got the cdi and put it back on the servo
@vtrn_raptor go to page 86 and read
Will do mate
don't go playing with carb setting yet tho I must stress to you that you should take your time and do every thing methodically or you could end up going in circles with problems you created which is what it sounds like you were doing, to begin with,
this could still be a few things ie needle jets throttle even fuel line so start from the top -
Is it possible that my exhaust is filled with something as reading this page says about Miss firing could be down to exhaust spark plug or air filter
Or could this isue be down to stale petrol as it's probably been sat in the bike for 2-4 months
@vtrn_raptor stale fuel certainly won't be helping. I suggest you get some fresh in there
for instance my brothers cbr 600f just stopped running when we were going out one day I started taking the carb off and seen a fuel pump and the carbs still got cleaned but it was the fuel pump so didn't even have to be cleaned they were minging anyways though the point is start from the top if I had checked the pump, to begin with, time would not have been wasted if fact I would have told him don't worry the bike would be fine without it there for extra fuel at really high rpm and just taken it out at the side of the road that day and we would have had a good day out
From doin a bit a research on it stale gas can make it bog kill spark plugs and not fully burn
The pump on the dt is a tap isn't it ?
@vtrn_raptor hahaha this is perfect exactly what I mean :grin: :grin: :grin: how long it been in there and that probably not it thou but don't help matters
@vtrn_raptor there is no pump on a dt was using the story as example
