  4. Need help
Need help
167 Posts 11 Posters 102.0k Views
  • V
    V
    vtrn_raptor
    I'll take it for a longer ride later with some fresh fuel and see how it is as didn't take it very far earlier and go from their as bike hasn't been riden in about 2 months and only done 30miles on new piston
    • V vtrn_raptor
      @vtrn_raptor Not being funny. My DT was off the road two years. Literally kicked it over on a brand new engine and road it fine.
      Same fuel, didn't even bother charging the battery.
      So I doubt it's the fuel really.
      • terry.tzT
        terry.tzT
        terry.tz
        @calum said in Need help:
        Fuck sake.
        calm down I didn't contradict you pal every bike has its own character and our bikes are clearly different I did not say it's bad or good I just said mine starts fine cold without choke runs sweet with a nice brown tinge to the tip now I played a bit with the carb im just saying to him don't worry about that its a sign, not an issue
        • terry.tzT terry.tz
          Fuck sake.
          @terry-tz Nah not aimed at you bud.
          I said in my previous post that once it starts to die down he needs to take the choke off. Choke is just for that initial few moments.
          I was annoyed because it seemed like he didn't read my post. Wasn't digging at you bud.
          terry.tzT 1 Reply Last reply
            terry.tzT
            terry.tzT
            terry.tz
            @calum i get you
            • V
              V
              vtrn_raptor
              I did read it just thought you meant it was supposed to stay running with it on
              • V vtrn_raptor
                @vtrn_raptor Nope. Once it starts to die off, that's when choke is not needed.
                I remember when I was a wee lad going to school, I used to start the DT, choke on, by the time I walked to lock the house, put my thermals on, the bike had cut out. So needed to start it with choke off.
                Doesn't take long.
                • V
                  V
                  vtrn_raptor
                  I've learnt that every bikes different kept comparing this one to my last one and boy what a mistake that was
                  • NINJAN
                    My DTR would never start without the choke on, even when the engine was hot. It was always choke on, kick start, then either run for a bit when cold or choke off as soon as I had my helmet and gloves on when the engine was previously warm. I just assumed that was how it was???
                    • V
                      V
                      vtrn_raptor
                      That's what i thought with my last Dt wouldn't start without choke had to keep choke on till it was warm could have been down to the fact it was a 170 but god knows that bike met it's bitter end when I trusted a garage with it and the Prick killed it then denied doing anything bad to it
                      • V vtrn_raptor
                        @vtrn_raptor Those 170 kits were actually pretty bullet proof.
                        • V
                          V
                          vtrn_raptor
                          Wasn't after the garage got hold of it 😂
                          • V vtrn_raptor
                            @vtrn_raptor 😂
                            • V
                              V
                              vtrn_raptor
                              This is what the plug looks like now after riding and running for about 15 mins 0_1502560619031_IMG_3530.JPG
                              terry.tzT 2 Replies Last reply
                              • V vtrn_raptor
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @vtrn_raptor camera not focused properly but that defo looks like it's wet and oily and low temp so over fueling
                                • V vtrn_raptor
                                  terry.tzT
                                  terry.tzT
                                  terry.tz
                                  @vtrn_raptor did you try without the side case
                                  • V
                                    V
                                    vtrn_raptor
                                    Not just yet but I have a question what is the throttle needle for and can the position it's in cause a problem
                                    • V vtrn_raptor
                                      terry.tzT
                                      terry.tzT
                                      terry.tz
                                      @vtrn_raptor yes it can cause problems
                                      and it is another throttle stage for more fuel ie 1/2 to 3/4 throttle and
                                      • V
                                        V
                                        vtrn_raptor
                                        So this could be my issue. The guy I brought the bike off had pinned the pv and have messed about with the carb to get it to run after changing the piston I realised their must have been an air leak somewhere on the bike as wouldn't stay running. I took the carb off to discover the mixture screw was seized so I replaced the carb the only thing I haven't done is touch the needle on the throttle and left it how I got the bike
                                        • V vtrn_raptor
                                          terry.tzT
                                          terry.tzT
                                          terry.tz
                                          @vtrn_raptor ok your better off do as @Calum said to you set the carb up as it was stock manual will have all the settings for you
