  4. Need help
Need help
167 Posts 11 Posters 102.0k Views
  • NINJAN
    My DTR would never start without the choke on, even when the engine was hot. It was always choke on, kick start, then either run for a bit when cold or choke off as soon as I had my helmet and gloves on when the engine was previously warm. I just assumed that was how it was???
    • V
      V
      vtrn_raptor
      That's what i thought with my last Dt wouldn't start without choke had to keep choke on till it was warm could have been down to the fact it was a 170 but god knows that bike met it's bitter end when I trusted a garage with it and the Prick killed it then denied doing anything bad to it
      • V vtrn_raptor
        @vtrn_raptor Those 170 kits were actually pretty bullet proof.
        • V
          V
          vtrn_raptor
          Wasn't after the garage got hold of it 😂
          • V vtrn_raptor
            @vtrn_raptor 😂
            • V
              V
              vtrn_raptor
              This is what the plug looks like now after riding and running for about 15 mins 0_1502560619031_IMG_3530.JPG
              terry.tzT 2 Replies Last reply
              • V vtrn_raptor
                terry.tzT
                terry.tzT
                terry.tz
                @vtrn_raptor camera not focused properly but that defo looks like it's wet and oily and low temp so over fueling
                • V vtrn_raptor
                  terry.tzT
                  terry.tzT
                  terry.tz
                  @vtrn_raptor did you try without the side case
                  • V
                    V
                    vtrn_raptor
                    Not just yet but I have a question what is the throttle needle for and can the position it's in cause a problem
                    terry.tzT 1 Reply Last reply
                    • V vtrn_raptor
                      terry.tzT
                      terry.tzT
                      terry.tz
                      @vtrn_raptor yes it can cause problems
                      and it is another throttle stage for more fuel ie 1/2 to 3/4 throttle and
                      • V
                        V
                        vtrn_raptor
                        So this could be my issue. The guy I brought the bike off had pinned the pv and have messed about with the carb to get it to run after changing the piston I realised their must have been an air leak somewhere on the bike as wouldn't stay running. I took the carb off to discover the mixture screw was seized so I replaced the carb the only thing I haven't done is touch the needle on the throttle and left it how I got the bike
                        • V vtrn_raptor
                          terry.tzT
                          terry.tzT
                          terry.tz
                          @vtrn_raptor ok your better off do as @Calum said to you set the carb up as it was stock manual will have all the settings for you
                          • V vtrn_raptor
                            terry.tzT
                            terry.tzT
                            terry.tz
                            @vtrn_raptor but before you go tinkering as I said yesterday start from the top did you replenish the fuel
                            • V
                              V
                              vtrn_raptor
                              Yeah has fresh fuel in the bike now
                              • V vtrn_raptor
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @vtrn_raptor have you checked I know this is silly and I know I'm contradicting myself but considering I think its rich but check anyway is the fuel flowing fine from tank to carb
                                • V
                                  V
                                  vtrn_raptor
                                  • terry.tzT
                                    terry.tzT
                                    terry.tz
                                    i think that is yes but you should check manual
                                    • V
                                      V
                                      vtrn_raptor
                                      I've come to the conclusion something is wrong with the carb as wasn't having this problem with old carb but was running to lean that's the reason I got this one that's probably why I got the carb so cheap ..........
                                        My clip is in the middle, yours is a noth lower, which raised the needle, making it richer.
                                        • V vtrn_raptor
                                          terry.tzT
                                          terry.tzT
                                          terry.tz
                                          @vtrn_raptor have you documented the setting on the carb before you started playing with them
