  4. Need help
Need help
167 Posts 11 Posters 102.0k Views
  • V vtrn_raptor
    This is what the plug looks like now after riding and running for about 15 mins 0_1502560619031_IMG_3530.JPG
    terry.tzT
    terry.tzT
    terry.tz
    @vtrn_raptor did you try without the side case
    • V
      V
      vtrn_raptor
      Not just yet but I have a question what is the throttle needle for and can the position it's in cause a problem
      terry.tzT 1 Reply Last reply
      • V vtrn_raptor
        terry.tzT
        terry.tzT
        terry.tz
        @vtrn_raptor yes it can cause problems
        and it is another throttle stage for more fuel ie 1/2 to 3/4 throttle and
        • V
          V
          vtrn_raptor
          So this could be my issue. The guy I brought the bike off had pinned the pv and have messed about with the carb to get it to run after changing the piston I realised their must have been an air leak somewhere on the bike as wouldn't stay running. I took the carb off to discover the mixture screw was seized so I replaced the carb the only thing I haven't done is touch the needle on the throttle and left it how I got the bike
          terry.tzT 2 Replies Last reply
          • V vtrn_raptor
            terry.tzT
            terry.tzT
            terry.tz
            @vtrn_raptor ok your better off do as @Calum said to you set the carb up as it was stock manual will have all the settings for you
            • V vtrn_raptor
              terry.tzT
              terry.tzT
              terry.tz
              @vtrn_raptor but before you go tinkering as I said yesterday start from the top did you replenish the fuel
              • V
                V
                vtrn_raptor
                Yeah has fresh fuel in the bike now
                • V vtrn_raptor
                  terry.tzT
                  terry.tzT
                  terry.tz
                  @vtrn_raptor have you checked I know this is silly and I know I'm contradicting myself but considering I think its rich but check anyway is the fuel flowing fine from tank to carb
                  • V
                    V
                    vtrn_raptor
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      i think that is yes but you should check manual
                      • V
                        V
                        vtrn_raptor
                        I've come to the conclusion something is wrong with the carb as wasn't having this problem with old carb but was running to lean that's the reason I got this one that's probably why I got the carb so cheap ..........
                          My clip is in the middle, yours is a noth lower, which raised the needle, making it richer.
                          • V vtrn_raptor
                            terry.tzT
                            terry.tzT
                            terry.tz
                            @vtrn_raptor have you documented the setting on the carb before you started playing with them
                            • V
                              V
                              vtrn_raptor
                              The first carb couldn't check nothing as mixture screw was seized but with this one everything was set up how the Haynes said but looking at the carb compared to the old one theirs pipes missing it's got aftermarket hex screw holding the face on and what's worse is the kid I got it off kept his Dt and claimed the carb was a spare so was probably broke when I brought it can't really complain though only paid £25
                              • V vtrn_raptor
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @vtrn_raptor so why did you think it could be the needle then
                                • terry.tzT terry.tz
                                  @terry-tz might be missing something but given everyone is suing rich why didn't he adjust the needle to suit mine was lean and runs much better on the lowest needle clip?
                                  • terry.tzT
                                    terry.tzT
                                    terry.tz
                                    you keep rushing into things and you're gonna be chasing your tail like a jim carrey nut job a long time before that bikes fixed
                                      terry.tzT
                                      terry.tzT
                                      terry.tz
                                      @declan personally I don't think he should even have it open yet but I'm no expert
                                      • terry.tzT
                                        terry.tzT
                                        terry.tz
                                        also, it's showing symptoms of rich running from start up before needle and main jet so it probably not the needle anyways
                                          Needle clip position isn't going to make it run as rich as it is.
                                          Get that carb bog stock.
                                          Stlck needle, stock position, stock air screw stick idle speed.
                                          It's running way too rich, but at wide open throttle it is only the main jet that you are concerned with. So why even bother with the needle position when it is not running right at wide open throttle.
