  4. Need help
Need help
167 Posts 11 Posters 96.9k Views
    @terry-tz might be missing something but given everyone is suing rich why didn't he adjust the needle to suit mine was lean and runs much better on the lowest needle clip?
    terry.tzT Offline
    terry.tzT Offline
    terry.tz
    @declan personally I don't think he should even have it open yet but I'm no expert
    • terry.tzT Offline
      terry.tzT Offline
      terry.tz
      also, it's showing symptoms of rich running from start up before needle and main jet so it probably not the needle anyways
        Needle clip position isn't going to make it run as rich as it is.
        Get that carb bog stock.
        Stlck needle, stock position, stock air screw stick idle speed.
        It's running way too rich, but at wide open throttle it is only the main jet that you are concerned with. So why even bother with the needle position when it is not running right at wide open throttle.
          The needle overlaps both bottom and top end, so will fuel height in the carb, verify that its stock.
          • J Jens Eskildsen
            @jens-eskildsen But once its wide open throttle, the needle is clear of the main jet thus no longer part of the fuel metering process.
              Try yourself mate, if you have a clean reving bike, I can promise you that making big changes to the needle will also affect just of idle, and WOT aswell.
              I had tonnes of issues due to the PO messing with the carb, so I've been all over this quite a few times.
              2-strokes are just very sensitive to jetting, half a notch on the needle on mine will make the bike go from runnning from okay to great.
              • V Offline
                V Offline
                vtrn_raptor
                I did change the needle but was not different I even pinned the pv again just to see if it was the pv causing the lack of power but no it was still the same might just take my carb off and take it to fowlers and get the specialists to rebuild and clean it and see if that helps the problem as would be loads cheaper than buying a new carb
                  Yeah, somthing sounds way off.
                  Have you checked the fuelheight in the carb? Does the carb overflow and throw gas on the ground ?
                    Are you by any chance missing the washer just under the main jet?
                    That will cause a very rich condition.
                    • V vtrn_raptor
                      @vtrn_raptor It's the fueling not the powervalve. That's why it's spluttering.
                      • V Offline
                        V Offline
                        vtrn_raptor
                        Nope no fuel on the ground and I don't recall their being a washer under the main jet either
                        • V vtrn_raptor
                          @vtrn_raptor Well there is...
                          Can't say I ever noticed that lol.
                          But I guess I'm not running the stock carb.
                          • V Offline
                            V Offline
                            vtrn_raptor
                            I'm going to do what you said and put carb back stock and work from their
                            • V Offline
                              V Offline
                              vtrn_raptor
                              Got someone who knows their way around a dt coming up tonight so fingers crossed 🤞
                                Ifyoure missing the washer, that could very well be your main problem, please give it a shot!
                                When youre missing the washer, the carb will suck fuel around the mainjet aswell, making it very very rich.
                                • V Offline
                                  V Offline
                                  vtrn_raptor
                                  It was the washer causing the problem the bikes running so nice now
                                  declanD terry.tzT 2 Replies Last reply
                                  • V vtrn_raptor
                                    @vtrn_raptor yesssssssss happy for you
                                    • V vtrn_raptor
                                      terry.tzT Offline
                                      terry.tzT Offline
                                      terry.tz
                                      @vtrn_raptor congrats
                                      • V Offline
                                        V Offline
                                        vtrn_raptor
                                        Thanks guys I'll make a build thread soon as I have some time to kill with a few pictures
                                        • MightymanM Offline
                                          MightymanM Offline
                                          I'm very glad you got this sorted without the help of a garage. It would have been wasted money mate! 👍
