  4. Need help
Need help
167 Posts 11 Posters 99.0k Views
    Try yourself mate, if you have a clean reving bike, I can promise you that making big changes to the needle will also affect just of idle, and WOT aswell.
    I had tonnes of issues due to the PO messing with the carb, so I've been all over this quite a few times.
    2-strokes are just very sensitive to jetting, half a notch on the needle on mine will make the bike go from runnning from okay to great.
    • V
      V
      vtrn_raptor
      I did change the needle but was not different I even pinned the pv again just to see if it was the pv causing the lack of power but no it was still the same might just take my carb off and take it to fowlers and get the specialists to rebuild and clean it and see if that helps the problem as would be loads cheaper than buying a new carb
        Yeah, somthing sounds way off.
        Have you checked the fuelheight in the carb? Does the carb overflow and throw gas on the ground ?
          Are you by any chance missing the washer just under the main jet?
          That will cause a very rich condition.
          • V vtrn_raptor
            @vtrn_raptor It's the fueling not the powervalve. That's why it's spluttering.
            • V
              V
              vtrn_raptor
              Nope no fuel on the ground and I don't recall their being a washer under the main jet either
              • V vtrn_raptor
                @vtrn_raptor Well there is...
                Can't say I ever noticed that lol.
                But I guess I'm not running the stock carb.
                • V
                  V
                  vtrn_raptor
                  I'm going to do what you said and put carb back stock and work from their
                  • V
                    V
                    vtrn_raptor
                    Got someone who knows their way around a dt coming up tonight so fingers crossed 🤞
                      Ifyoure missing the washer, that could very well be your main problem, please give it a shot!
                      When youre missing the washer, the carb will suck fuel around the mainjet aswell, making it very very rich.
                      • V
                        V
                        vtrn_raptor
                        It was the washer causing the problem the bikes running so nice now
                        declanD terry.tzT 2 Replies Last reply
                        • V vtrn_raptor
                          @vtrn_raptor yesssssssss happy for you
                          • V vtrn_raptor
                            terry.tzT
                            terry.tzT
                            terry.tz
                            @vtrn_raptor congrats
                            • V
                              V
                              vtrn_raptor
                              Thanks guys I'll make a build thread soon as I have some time to kill with a few pictures
                              • MightymanM
                                I'm very glad you got this sorted without the help of a garage. It would have been wasted money mate! 👍
                                • terry.tzT
                                  terry.tzT
                                  terry.tz
                                  best part its one of them things were a garage won't have a clue can't imagine this being that common is it @Jens-Eskildsen
                                    Mine were the same when i bought it. I chased it for weeks, leening out the whole carb before i looked at a parts fiche.
                                    I knew right away what was wrong when i saw the missing washer.
                                    I think its just easy to misplace that one.
                                    terry.tzT 1 Reply Last reply
                                    • J Jens Eskildsen
                                      terry.tzT
                                      terry.tzT
                                      terry.tz
                                      @jens-eskildsen fare enough
                                      • V
                                        V
                                        vtrn_raptor
                                        Feels good to be riding again lol now I have another question how can I replace a steering lock
                                        • V vtrn_raptor
                                          terry.tzT
                                          terry.tzT
                                          terry.tz
                                          #130
                                          @vtrn_raptor drill it out and replace it there is a thread on here about it I think
