  3. Framework
  4. Foot pegs
Foot pegs
31 Posts 6 Posters 11.5k Views
  • J Jens Eskildsen
    tw200 ones fit, theres tons of wide ones on ebay. getthe steel ones, the ones in alu will break (did for me)
    I have been using the steel ones for my xt600 for years. All you need to do is to drill a hole for the spring, in one of them, otherwise bolt on pegs.
    @jens-eskildsen drill hole for spring don't you mean for the pin?
      I used a set of these:
      declanD ZrakoZ 2 Replies Last reply
        @calum bit pricey though ain't they but I guess if you want the nice parts you gotta pay
          @declan I'm sure there is some china knock offs lying around!
            No, for the (return)spring, the pin fits fine.
              @calum there is but they will still have the slant like my current ones have
                @declan Slant?
                Just grind them down so they fit properly.
                  @declan Slant?
                  @calum no it's the opposite like there's ever so slightly pointing down they work but I'm scared if I hear really wet my feet may slip on jumps 0_1503178041737_IMG_1332.JPG
                    Anyone tried for example yz foot pegs ktm etc I put some oversized ones on mine but there slightly slanted I'm after a set I can get second hand maybe that will be a nice fit
                    @declan Are yours knackered, or are you just wanting some wider ones dude? I just sprayed mine up and they looked as good as new!!! 😉
                      @cyber-ninja wanted some that would be a better fit and I was hoping for second hand so I can get them cheap then paint em up
                        @declan As cheap as chips, so long as you don't mind the wait;
                        https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2060353.m570.l1313.TR0.TRC0.H0.Xtw200+foot+pegs.TRS0&_nkw=tw200+foot+pegs&_sacat=0
                        They even come with new springs and pins;
                        http://www.ebay.co.uk/itm/Foot-Pegs-Rest-Black-For-Yamaha-TTR90-TTR90E-CRF80-PW80-PW50-Pit-Dirt-Motor-Bike-/122653858300?hash=item1c8ebd59fc:g:RSAAAOSwN2VZQu-3
                          Get the steel ones please, the others is made from 100%pure chinesium.
                          This design is much more sturdy: http://www.ebay.com/itm/Steel-Foot-Pegs-For-Yamaha-PW-50-PW-80-TW-200-/310450858598?hash=item4848502a66:g:uUIAAOSw0UNZdwsd&vxp=mtr
                            Those apico ones I bought are ally and are well tough.
                              @calum yeah they're built like a tank lol
                              • J Jens Eskildsen
                                @jens-eskildsen only issue I have lads is these cheap ones look identical to the type that I have on the dt and like I say they are slightly slanted downwards I can get cheap pegs I'm just trying to make 💯 sure that they will fit and not slant down
                                  Mine are perfectly fine.
                                  • A
                                    A
                                    andrewj1680
                                    I've ordered a set of these 😜 the pivot back or forward too
                                    • A andrewj1680
                                      @andrewj1680 wow just came here to show off haven't you 😒 How much were those!
                                      • A
                                        A
                                        andrewj1680
                                        They were a tad expensive but its 1 of them things you only buy once aint it
                                        • A andrewj1680
                                          @andrewj1680 yeah I guess it is
