  3. Engine swaps for dummies!
13 Posts 7 Posters 2.8k Views
  • declanD Offline
    Can everyone with experience with engine swaps post what you come across the thought process what worked and what didn't so we can all better understand it thank you!
    • D Offline
      D Offline
      dan28
      I be fitted a Dt motor in a chopper that should have a v twin four stroke
      Fitting the engine required making new mounts etc but that's the easy part getting the exhaust an loom to fit was a nightmare
      What are you planning to do if you are swapping one 2 stroke for another it should be a case of chopping an moving the mounts but it's not always that simple if the engine has to mount through swing arm
      • D dan28
        @dan28 well I have a cpi sm 50 small and light the rear mount should work the front one needs widening in just trying to lean as much as possible if I happen to have the money to make it possible
        • P Offline
          P Offline
          PerithTV
          I've had problems with the swingarm pivot bolts that were not properly greased when installed completely seizing. I tried Pentrating oil, heat and the air hammer. None worked so i just used an angle grinder to cut the bolt.
          F ZrakoZ 2 Replies Last reply
          • P PerithTV
            F Offline
            F Offline
            @perithtv I've been there too. They'll be coming out once a year and regreased from now on
              I've never had issues with the swingarm bolt. having owned the bike since 5k miles, it's never cause me any grief. Once it was removed it was regreased and that's that.
              I grease it everytime I remove it, but I won't remove it to regrease it.
              Same goes with the shock linkages. Many have trouble with those.
              F 1 Reply Last reply
                F Offline
                F Offline
                @calum shock linkages are ok on mine as they're fitted with grease nipples.
                  @finnerz89 And what 17 year old greases those up, more interested in human nipples lol.
                  • NottsbikerN Offline
                    NottsbikerN Offline
                    Just pulled out all the bushes etc out of the TDR linkage and have made a start on the swingarm but ran out of time over the weekend. Grease nipples are good when they work, but nothing can replace taking something apart, cleaning it fully and putting back together again - why not make it a winter task, or do it when off work sometime.
                    • NottsbikerN Nottsbiker
                      F Offline
                      F Offline
                      @nottsbiker my plan exactly
                      @Calum I'm 28 and still the same..... Lol
                        @finnerz89 my front engine mount is solid can't loosen it I tried everything my swing arm one was good though I had to leave the engine in the frame to rebuild it
                          NottsbikerN Offline
                          NottsbikerN Offline
                          @declan said in Engine swaps for dummies!:
                          Get some heat and penetrating fluid in there (diesel works too) and alternate trying to turn it both ways with hitting it. Be careful if you try and hit the threaded end as you will need to keep the nut on in case you peen it over or miss and damage the threads.
                          • P PerithTV
                            ZrakoZ Offline
                            ZrakoZ Offline
                            Zrako
                            @perithtv I've been there too few months ago. Soaking , heating etc etc nothing
                            Take off everything possible what can restrict you in the back and chop the bolt on as much places as angle grinder let you. I had 4 cuts and lifted the pieces off. Bought brand new guts for it and there is more grease then metal on it 😂 damaged my axe on it too 😁
                            1979 Jawa Mustang 50
                            2003 Gilera DNA 125 R.I.P
                            2015 Keeway TX 125 SM
                            2006 Yamaha DT 125 X
