  3. Carb clean abs rebuild help
33 Posts 4 Posters 6.2k Views
    @finnerz89 It's driven off a nylon cog directly from crankshaft. So yes and no. It is driven from both the throttle and crank.
    F Offline
    F Offline
    @calum I could've worded that better, driven off the crank, controlled by the throttle. Either way a rich fuel/air mix won't really affect the amount of oil supplied by the pump will it?
    • F finnerz89
      @finnerz89 I think, in this instance, the fuel change is so little that it's not really the issue here.
      The issue is that putting a washer behind the choke isn't fixing the problem, and I think we're all in agreement with this.
      F 1 Reply Last reply
        F Offline
        F Offline
        @calum most definitely lol
        • terry.tzT Offline
          terry.tzT Offline
          terry.tz
          @Calum agreed but the oil might still be an issue as the choke is not driven off the throttle and is supplying some fuel without the throttle ie no oil well low oil relative to fuel and it probably won't keep enough flow in the mid-range so low oil plus low fuel I would be riding with caution unless I was confident I was getting enough might not be much difference but I suppose it depends on what you use your bike for
          • terry.tzT terry.tz
            @terry-tz Iโ€™m not by any means saying that this is a perfect fix but itโ€™s yhe best I can do at this time
            • terry.tzT Offline
              terry.tzT Offline
              terry.tz
              @declan I'm not digging mate I would probably do the same I mean I been running mine with twisted bottom yoke from were I came off, br10 plug no br9's at the time, buckled front wheel and a few things holding together with cable ties :grin: and a few other bits and bobs just pointing out the risks of not fixing
              terry.tzT 1 Reply Last reply
                terry.tzT Offline
                terry.tzT Offline
                terry.tz
                @terry-tz oh ye guys remember the thread about iridium plugs well I restricted my bike for a friend never ridden before and it went around the field and the plug was foiled tried cleaning multiple times like 5 - 10, in the end, i put the br10es in iridium plugs are sh!te I tried them one last time and it let me down that's the last time I ever use one again
                  F Offline
                  F Offline
                  @terry-tz I've ran iridium plugs in mine with no issues, can't say I noticed a difference to standard though
                  • F finnerz89
                    terry.tzT Offline
                    terry.tzT Offline
                    terry.tz
                    @finnerz89 there ok just no reliable at all like you probably have your bike running sweet were as mines, not that sweet running and I restricted it which made it more oily so I mean if your all done tinkering there ok but for the extra price for the not so noticeable performance gain you might as well burn your money and set off early for everything in case you need to change a plug very slightly exaggerated
                      F Offline
                      F Offline
                      @terry-tz haha ๐Ÿ˜‚ were yours genuine NGK's? I've heard there's a lot of fakes knocking about on eBay that really are shite
                      • F finnerz89
                        terry.tzT Offline
                        terry.tzT Offline
                        terry.tz
                        @finnerz89 not the first time I heard this lol so i got it from www.sparkplugs.co.uk
                        • terry.tzT Offline
                          terry.tzT Offline
                          terry.tz
                          that's the reason they had another chance
                          • F Offline
                            F Offline
                            Ahh fair enough then. Every bike is different lol
