  3. Off Topic
  4. Anyone got a Dt running better than this?
30 Posts 8 Posters 7.0k Views 1 Watching
  • Irongamer727I Offline
    https://youtu.be/dCY071hQcJ0
    Owner claims 160 kph top speed.
    Sick acceleration.
      Clearly fake. He's sped it up.
      I remember seeing this ages ago.
        @calum you sure?
        • Irongamer727I Irongamer727
          @calum you sure?
          He's one hell of an editor that case.
          Look at this https://youtu.be/N264vFDYO8I
            That second one don't look as quick.
            Besides the fact, they don't look that quick anyway....
            • F Offline
              F Offline
              Not a chance. How can he claim 160kph without a speedo that actually displays that figure?
              Also clearly sped up, all my helmet cam video looks slower than it was
              • MightymanM Offline
                MightymanM Offline
                I wouldn't be so sure he's actually sped up the video. At the most his Speedo is reading incorrectly (from change in wheelsize possibly), but even then is this so unbelievable? He is lifting it in 2nd and a tiny bit in 3rd from power alone, so there must be a fair bit of pull from that bike.
                The vid may look sped up because of his surroundings moving so fast, but if you take a look at this video, about 10 seconds in you would think I'm going faster than I actually was.
                https://youtu.be/RcgQzlFc5Ps
                • MightymanM Mightyman
                  @mightyman indeed his bike pulls HARD.
                    Yeah maybe. I wouldn't say it's spectacular though. My DT runs faster than that, and I wouldn't comsider my dt fast
                      @calum dt125?
                        @calum dt125?
                        @irongamer727 Yes?
                          @irongamer727 Yes?
                          @calum what setup are you running?
                            @irongamer727 TZR Belgarda RR Barrel and Head ported by Mick Abbey and the squish band improved for peak power. The compression ratio has been increased and a forged domed piston placed along side a lighter forged connecting rod. TZR RR Belgarda Dellorto VHSA Carb with a hand crafted underslung pipe with a carbon fibre end can for pure performance. Also running RAM air pod filter to maximise air intake. The ignition system has been completely swapped out for a custom ignition system provided by Zeeltronic, the map has then been fine tuned to put all of the pieces of the puzzle together.
                            That combined with lighter components, supermoto wheels and the removal of any unnecessary weight.
                            So it's not just a slapped on Athena kit and a slightly sped up video.
                            2 Strokes DO NOT LIKE over square engines. Optimum two strokes work where the bore size matches the stroke. Increasing the bore will greatly reduce potential peak power, but naturally increases torque. It won't be enough to save it though, once my bike comes on full song, with a full 20k RPM limiter, and peak power shifted to around the 13k line, that DT won't stand a chance.
                            • terry.tzT Offline
                              terry.tzT Offline
                              terry.tz
                              I not even gonna read all these posts it's fake as f!!k speedo reading wrong but as for speeding up no man I think that mine would look the same if I recorded and it's not modified really
                              • N Offline
                                PPPHHHHHHHTTTTTTTT!!! My electric scooter reads 200Kph, 225Kph if I squat down!!! 😆
                                • DartyD Offline
                                  DartyD Offline
                                  wrote on last edited by Darty
                                  Before I blew apart my Powervalve..., I was hitting 80mph in 5th gear with my DT134cc TZR4DL 3MB top end.
                                  Completely destroyed it, never got to max it out, but it was pulling at 90mph!
                                  • terry.tzT Offline
                                    terry.tzT Offline
                                    terry.tz
                                    wrote on last edited by terry.tz
                                    I'm not doubting 100 mph out of DTRs and definitely not doubting it with a TDR TZR ect or being that quick there is better out there I'm doubting his speedo and his honesty on this video look at the difference in speeds and the speedo when slowing down for the car https://youtu.be/N264vFDYO8I but I don't doubt 100mph mine gets 80 not modified running a bit worse for wear and wants to lift in 3rd gear so 20mph is not much to gain when the power is there not being used
                                    • F Offline
                                      F Offline
                                      If I see a DT do a genuine 100mph I'll buy a hat and eat it
                                      CalumC terry.tzT 2 Replies Last reply
                                      • F finnerz89
                                        @finnerz89 My brothers 2001 dt125 indicated 100 with full dep ram air 38mm carb 170 athena
                                        https://www.youtube.com/watch?v=bOGAEzTaBgI
                                        But yeah, wouldn't trust the dt speedo, and we only measured it with a '97.... Fiat Punto GT, so hardly trustworthy lol
                                        Indicated and actually doing it are two different kettles of fish.
                                        F 1 Reply Last reply
                                        • F finnerz89
                                          terry.tzT Offline
                                          terry.tzT Offline
                                          terry.tz
                                          @finnerz89 I don't no I think it could different gearing modified well wind behind you I only get 10k revs out of my bike and I get 80mph maybe 85 downhill 😆 , not modified ish, I think original piston and rings, chain and sprockets
