  3. Top End
  4. pinned powervalve gap or no gap
15 Posts 4 Posters 3.8k Views
  • D
    dan28
    when the pv is pinned if I turn the plastic pulley so the hole in the pulley is just before the hole in the housing the pv feels smoth inside an there is no gap between the cylinder wall an the pv
    heres a photo of the pulley
    ![0_1514576704218_IMG_20171229_193021.jpg](Uploading 100%)
    • D
      dan28
      but if the hole in the plastic pulley is aligned with the housing there is a gap between the pv an the cylinder wall
      which way is correct
      ![0_1514576884859_IMG_20171229_192758.jpg](Uploading 100%) ![0_1514576906319_IMG_20171229_192709.jpg](Uploading 100%)
      • D dan28
        Irongamer727I
        Irongamer727I
        @dan28 reupload the pictures.
          @dan28 You need to wait for the upload to complete mate. What for the image to embed itself into the page before hitting submit Be paitient, you're working off a 2mb upload!
          D 1 Reply Last reply
            dan28
            @calum said in pinned powervalve gap or no gap:
            Each time I try to upload its says the image is too large an doesn't embed it
            Not sure why I m using the same phone an has worked on here before
            declanD 2 Replies Last reply
            • D dan28
              @dan28 so when you line the pv up like your supposed to inside the cylinder it’s restricting still? If so I recently discovered the same thing with mine so I set it before the hole
              • D dan28
                @dan28 yeah it won’t work that way anymore
                  Irongamer727I
                  Irongamer727I
                  @declan same for me
                  • Irongamer727I Irongamer727
                    @declan same for me
                    @irongamer727 for the pv or pictures?
                      Irongamer727I
                      Irongamer727I
                      @declan when aligned, the pv is not fully open.
                        @irongamer727 yes my theory is it’s a cheeky restriction?
                          Irongamer727I
                          Irongamer727I
                          @declan naah. It is clearly evident on my Athena 170. That's no restriction in that case
                            @irongamer727 ooh wonder why it’s that way then?
                              I never go by the hole. Just match it with the exhaust port and away you go.
                              • D
                                dan28
                                the plastic pulley has to aligned with hole to be able to pin it though unless I glue a washer on to the plastic pulley to align it before the hole
