  4. Break in new cylinder
52 Posts 6 Posters 10.4k Views
    @Irongamer727 https://youtu.be/WwFUzgr2xnA there it helped me a lot
    #21
    @Irongamer727 and don’t worry about Fouling plugs if you add oil to the tank as well as autolube I was running 165ml of oil to 5ltr of fuel aswell as enriched auto lube for months with no issue I was a bit paranoid I don’t recommend doing it though
      Irongamer727I
      Irongamer727I
      @declan haha was that during your break in?
      • Irongamer727I Irongamer727
        @irongamer727 I never recorded hours or miles so yeah and also after break in @Calum made me stop lol
        • Irongamer727I
          Irongamer727I
          O my god what a relief! Athena is up and running! Jesus Christ I have never ever been so afraid of something going wrong. Hopefully the worst part is over. Still afraid a circlip will come loose and mess EVERYTHING up. But, I've done my best, bring on the summer😁
            @irongamer727 nice one bud.
              Jens Eskildsen
              Hopefully you will keep us updated with how you like it, as you clock some miles on her πŸ™‚
              • J Jens Eskildsen
                Irongamer727I
                Irongamer727I
                @jens-eskildsen sure will
                • Irongamer727I
                  Irongamer727I
                  I'm getting more acquainted with the brake in procedures. I've always thought you couldn't be too careful running an engine in. Obviously I was wrong. The fact that idling can glaze the bore scares me! I mean you need a good 20 minutes to bled the cooling system of air.
                  Guess a moderate run in with a bit of variation of revs is preferable.
                    I always thought it was giving it too much chst before thr rings have bedded in causes glazing.
                    Either way, get it runing and put some miles intonit before hammeringnit. That's my advice. Two strokes don't last forever so it's a moot point if it lasts +-1k miles. The main thing is getting that fueling spot on.
                      @calum 20 minutes to bleed the cooling it only took mine a few seconds
                      • O
                        O
                        You should warm the engine thoroughly to make sure thermostat opens and gives full flow to water passages, otherwise pockets of air could remain
                          Irongamer727I
                          Irongamer727I
                          @declan after 20 minutes there were still air left. But at that point I felt satisfied.
                            I don't think I've really actively bled the coolant system on any of my builds. Fire her up rad cap off, just top it up. Quick blip round the block top her up jobs a goodun
                            Irongamer727I declanD 3 Replies Last reply
                              Irongamer727I
                              Irongamer727I
                              @calum works for some
                                @calum well I took my cap off started the bike and after a little bit the coolant expanded and started overflowing so it only took me a few seconds maybe 30s tops
                                  Irongamer727I
                                  Irongamer727I
                                  @declan ideally you want to warm it up to operating temperature with cap off. That way you know there won't be excessive amounts of air once you're out riding. My radiator started pissing out coolant through the overflow hose due to improper bleeding.
                                    @irongamer727 so I just let it spill out?im pretty sure I managed to get all the air out of mine
                                      Irongamer727I
                                      Irongamer727I
                                      @declan lucky you! I'm only telling you what I experienced with my bike. πŸ˜‰
                                        Irongamer727I
                                        Irongamer727I
                                        @calum you think it's possible to glaze the bore of a plated cylinder? (Nikasil)
                                          @irongamer727 Yes
