  3. Exhaust
  4. Exhaust almost touching tank
11 Posts 6 Posters 2.3k Views
  • Irongamer727I Offline
    My Arrow exhaust is dangerously close to the tank, according to my measurements around 4 mm. Will this be a problem?
      Got any photos bud?
      I mean my DEP was close, but not that close.
          Doesn't look too bad, is it close is it?
            @calum 4 mm
            declanD N 2 Replies Last reply
            • Irongamer727I Irongamer727
              @calum 4 mm
              @irongamer727 not a very good picture can you get one so we can see the underside of the tank
              • Glynn123G Offline
                Glynn123G Offline
                Glynn123
                Line the underside of your tank with heatproof asbestos or similar exhaust wrap if your worried, I done this to my water expansion tank as it touched my silencer, but really I wouldn't worry.
                • O Offline
                  O Offline
                  Asbestos! You are kidding! Buy some self adhesive heat reflecting foil readily available on ebay, used it on new side panels, easy to do.
                  Glynn123G 1 Reply Last reply
                  3
                  • O oldman
                    Glynn123G Offline
                    Glynn123G Offline
                    Glynn123
                    @oldman asbestos exhaust wrap, very good stuff
                    • O Offline
                      O Offline
                      In true blue Peter fashion here is one I prepared earlier. Would avoid anything containing any asbestos like the plague, not sure if modern exhaust wrap contains it any more, more likely to contain glass fibres now. 0_1520374804511_20180112_133738-1024x576.jpg 0_1520374817151_20180112_140037-1024x576.jpg
                        @calum 4 mm
                        @irongamer727 I did the same mod as @oldman suggested. I used this stuff from ebay;
                        https://www.ebay.co.uk/itm/Fairing-Panel-Engine-Exhaust-HEAT-SHIELD-Track-Day-Bike-Race-Bike-Self-Adhesive-/131062781562?hash=item1e83f3567a
                        It was top quality, super easy to use and worked really well too !!! 😉
