  4. Coolant problem
Coolant problem
10 Posts 5 Posters 2.0k Views
  • B Offline
    B Offline
    Bananper
    I have a weird problem on my dt. The coolant is going back to the expansion bottle and it gets filled up and leaks out, and when i open the radiator and rev the bike it spits out water. Ive tried two heads, and swapped headgaskets. Changed the bearing with the water pump. What could cause this?
    • B Bananper
      NINJAN Offline
      NINJAN Offline
      @Bananper Is the water pump performing correctly or maybe a blocked pipe perhaps???
      B 1 Reply Last reply
        B Offline
        B Offline
        Bananper
        @NINJA the waterpump impeller is turning as it should
        • B Bananper
          NINJAN Offline
          NINJAN Offline
          @Bananper In the correct direction? I'd check the pipes next then, if all is well then what has changed to create this problem, or has it just occurred on it's own???
            B Offline
            B Offline
            Bananper
            @NINJA i swapped the whole engine. There has always been something wrong with the cooling system in one way or another ever since
            • Louis-DT-WRL Offline
              Louis-DT-WR
              If it's going into the expan then it's leaking past the cap. Try a new cap 1.1 bar
              • Louis-DT-WRL Louis-DT-WR
                B Offline
                B Offline
                Bananper
                @Louis-James yeah but it should not be that much pressure
                • DanRacingD Offline
                  DanRacingD Offline
                  DanRacing
                  @Bananper said in Coolant problem:
                  Your cylinder gasket surface might not be good, or your nuts not torqued enough
                  • B Offline
                    B Offline
                    Bananper
                    When i took of my cylinder head i could see the piston had water on top, and i pulled of the cylinder and the cylinder gasket was really blown. Water everywhere on the piston but no major damage
                    • MightymanM Offline
                      MightymanM Offline
                      Might sound silly but you are using a genuine head gasket or an Athena one yes?
