Aprilia RS250 1999 Mugello Replica
what method should i use to paint the calipers?
and should i rebuild the calipers or no need?
@pedrobatista10 If you can get the parts to rebuild, then I would.
I remember one day riding to work, the rear brake seals failed. Leaking fluid all over my wheels. Discolouring the paint work :(
@pedrobatista10 If you wish to repaint them then just give them a rub down with some wet n' dry, then respray them with some Very High Temperature paint for a good finish. If the pistons are not damaged in any way, then you could replace the seals if needs be? I would perform a full strip down, thoroughly clean everything with a pressure washer, then give the outside of the pistons a very light rub with some fine wet n' dry and ruba small amount of copper slip on the outsides only. Then rebuild with new seals if required and perhaps new brass banjo bolts & nipples. They look to be in good overall condition, so a strip, clean, re-grease and rebuild might just be enough??? ;)
guys i think i will use vapour blasting services on carbs, engine cases, brembo calipers and some other parts to make it look mint condition. and price is reasonable.
i saw some photos and i like how it looks.
@NINJA @Calum its possible to powder coating the calipers? i want the original gold colour on them.
@pedrobatista10 yes they can be powder coated, seek out a local firm and ask their advice.
hi
i will send my carburetors and brembo calipers to rebuild to "MHF Restoration Macclesfield Cheshire" in UK. they do amazing jobs in restauration projects.
anyone used this company before?
Hi
Long time without parts, so i will update with big package from BlackFriday that arrived today
Brembo RCS19
Brembo Rear Disc's and brembo pads
TWM Clutch Lever
TYGA Rear Step kit with carbon cover's
Mellotti handlebars and triple clamps
Domino Throtlei keep the same brands for this rs250 build. why change when the quality is very good :blush:
still lots of parts to buy ...
hope you like it
@Calum thanks ;)
it hurts my wallet building this 2 bikes, but i dont regret it. with time i will finish this one too
and living with parents helps to save cash for my hobbies :)
next week im receiving Transmission Kit from Renthal from reputable seller in UK (TheTuningWorks)
@Calum thanks ;)
@pedrobatista10 But when they are finished and you get the joy of riding them, it all becomes worthwhile for-sure!!! :racing_motorcycle: :dash: :dash: :dash:
@Calum wow really? How could you resist to ride it, after that awesome build? 🤔
@pedrobatista10 It is not registered. Has no license plate.
hi guys, hope all of you are safe!
quick update for my project
received my calipers and carbs from MHF UK, they vapour blasted and pwder coated calipers and on the carbs vapour blast and ultrasonic cleaning. they look new now imo
you can see the condition of the calipers in this topic to check the difference :P
