  4. Cutting back ?
Cutting back ?
43 Posts 4 Posters 9.6k Views
    @dtlee as electronics warm up the resistance changes I'd hazard a guess with the problems your having you might have a faulty ignition coil as the coil warms up it might be out of spec this is easily checked with a multimeter via the Haynes manual, my bike cuts back at the same rpm never been able to remedy it- edit when I say ignition coil I mean the physical coil on the stator not the ht coil although that also can be an issue when it warms up
    DTleeD Offline
    DTleeD Offline
    DTlee
    @declan ah cool I’ll give that a go. So you’ve never managed to fix your problem of cutting back. It’s driving me mad I need to try and work it out
    • DTleeD DTlee
      Is there a way to check if the ignition is breaking down? I’ve checked everything mentioned above and cleaned the carb out etc. But still the book it’s cutting back intermittently at about 8000rpm. Before I split the casing and check seals I want to make sure I’ve checked everything else.
      It seems to run perfect for about 20mins riding the then seems to start and progressively gets worse. Could this be as it warms up the ignition is failing
      TIA
      @dtlee I had this recently on my DT when I replaced the perfectly working coil for a Chinese "Racing" coil. It worked fine for the first 100 miles then just refused to rev properly.
      Getting a nice genuine coil seemed to have fixed it.
      DTleeD 1 Reply Last reply
      • declanD Offline
        @dtlee yeah gonna try switching my main jet to a 240 see if that does anything gonna be a whole though as the engine is under the knife
          DTleeD Offline
          DTleeD Offline
          DTlee
          @calum I’m hoping this does the trick for me too where did you buy yours from?
            DTleeD Offline
            DTleeD Offline
            DTlee
            @declan I was thinking about jetting too but don’t want to mess with it too much as It used to ride fine before so I don’t think it will help me out
            • DTleeD DTlee
              @dtlee yeah in your case wouldn't mess with jets it's almost certainly electrical
                DTleeD Offline
                DTleeD Offline
                DTlee
                @declan just another though, I should probably checked that everything is earthed properly and that’s it’s not just something stupid like that? Do you know where the earthing point are on the bike. I had a quick look but couldn’t see anything obvious?
                  @dtlee Ignition coil should have an earth, voltage rectifier should have one and the battery terminal is earthed.
                    DTleeD Offline
                    DTleeD Offline
                    DTlee
                    @calum cheers I’ll check that just Incase it’s some thing stupid. I’m doing a 100 mile long distance trial in a couple or weeks so want it running right if I can get it to
                    • DTleeD Offline
                      DTleeD Offline
                      DTlee
                      wrote on last edited by DTlee
                      #30
                      Is there an easy way to temporarily disable the oil pump? I just want to check if it’s not packing up? It all looks correct but my plug is still oily and the bikes still cutting back at around 6-7krpm. I’ve checked the power valve isn’t the problem by pinning it open, took it for a ride and was still having the same issue. I was thinking of trying to pre mix the fuel and disable to oil pump to work out of its this causing the problem.
                      I’m running out of ideas with it. Failing this I guess it’s the ignition breaking down.
                      ( I have cleaned out the carb, fuel line and the tank also and now put back on the original exhaust )
                      Any ideas I’d be grateful
                      • DTleeD DTlee
                        #31
                        @dtlee @dtlee
                        I stuck the outlet (skinny) pipe into the inlet (fatter) pipe to cause a continuous loop. Been like that and ok for a 1000 miles, just don’t forget to block the inlet manifold oil inlet. I just cut and folded over some pipe, then zip tied it.
                        It stopped messing it’s pants all over the number plate now as well since I’ve been on pre mix...
                        I can’t remember what I’ve asked you before, but t did you do anything to the bike before it started happening? Even if it was a month before or seems irrelevant?...
                          @dtlee @dtlee
                          @spookdog
                          Did you remove and clean the outside of the needle valve tube? You tap it in and up through the throttle valve body to remove it. Mine was cemented up with micro fine sand stuff...
                          P.S. Did this come on all of a sudden or gradually get worse?...
                          DTleeD 2 Replies Last reply
                            @spookdog
                            DTleeD Offline
                            DTleeD Offline
                            DTlee
                            @spookdog It’s progressively got worse I think. All I have done is moved the read switch, put a full dep on and turned the power valve so it works. It used to do it after 40mins of riding but not it seem to do it constantly. Won’t got about 6-7krpm it just cuts back. I might try what you done with the oil pump just to rule another thing out. It’s massive annoying specially as I don’t a 100 mile long distance trial today and had to put up with that all day.
                              @spookdog
                              DTleeD Offline
                              DTleeD Offline
                              DTlee
                              @spookdog I cleaned the carb out and couldn’t see any blocked jets but I didn’t take the needle jet out. Might try this just Incase 👍🏻
                              • DTleeD DTlee
                                @dtlee I mean, since it started doing it since you "moved the reed valve" and "rotated the powervalve", have considered that this might be the problem?
                                  DTleeD Offline
                                  DTleeD Offline
                                  DTlee
                                  @calum it ran really well after I moved the Reed switch and done the power valve. Had all the power I want up to 11k rpm. Just seems to have got worse over time, just won’t rev past 6k rpm. I pinned the power open as I saw in one of your other posts but it still did the same. I’ll check the Reed is far away enough from the speedo tonight as it feels like a restriction. Other than this the bike runs perfectly.
                                  • DTleeD DTlee
                                    @dtlee
                                    Recheck the power valve isn’t 180 degrees out. Try putting the reed back in place and riding. Just to humour me 🙂...
                                      @dtlee
                                      DTleeD Offline
                                      DTleeD Offline
                                      DTlee
                                      @spookdog im going to put it back to standard and see how it runs and work backwards I think. Do you know if there a decent guide to doing to power valve with pictures or even a video? I just want to make sure it’s definitely right, I’m no mechanic but I like to do it myself so I can learn how it works in case of future problems
                                      • DTleeD DTlee
                                        @dtlee
                                        Everything you need is out there. I can’t help you, I don’t have a computer. I found everything out by searching on my phone...
                                        I would change the exhaust back to standard as well. Just to check and tick it off the list. You never know it could be blocked up with carbon oil and shit...
                                        The only other thing is: does it cut back regardless of throttle position? I can achieve 10,000 rpm at 1/2 throttle. Does yours cut back at different throttle position as it reaches 6-8k? Say if you maintain 1/3 throttle in second gear?
                                          @dtlee
                                          DTleeD Offline
                                          DTleeD Offline
                                          DTlee
                                          @spookdog thanks for your responses. I’m going to put everything back standard and double check the carb is spotless I’ve decided before I loose my Head with it all. It won’t go past 6k in any throttle position. I feel like it’s electronic so just want to rule everything else out first
