  3. Derestricting
  4. Derestrict yamaha dt 125 r 1997
66 Posts 5 Posters 30.7k Views
  • Mr ShadiM
    Mr ShadiM
    Mr Shadi
    Hello.
    I just bought myself a new Yamaha dt 125 r, and i want to derestrict it. But when i looked at the derestriction guide and then at my bike, the cdi wire colors were different. And I've been searching for a other guide to derestrict it but there is none.
    When I'm in the last gear the bike won't go over 80 km/h. If it goes i can hear the spark plug not getting spark and getting spark when its back at 80 km/h.
    If anyone could help me, it would be appreciated.
    markus.wM Mr ShadiM 2 Replies Last reply
    • Mr ShadiM Mr Shadi
      Hello.
      markus.wM
      markus.wM
      @Mr-Shadi what year is your bike?
      Mr ShadiM 1 Reply Last reply
        Sounds like reed switch to me...
        • markus.wM markus.w
          Mr ShadiM
          Mr ShadiM
          Mr Shadi
          @markus-w
          1997
          fcbb9b90-f903-45cf-a6ee-b25e92aafe12-image.png this one
          markus.wM 1 Reply Last reply
            Mr ShadiM
            Mr ShadiM
            Mr Shadi
            @Calum how can i adjust it?
              Does sound like a rev limiter. Is anyone else getting frustrated with language barriers? 😵‍💫
              Need someone with better knowledge about the rev counter ‘bulb’ and more patience to explain than me, anyone?…
              Someone translate scrimstangs site, maybe?…
                @markus-w
                1997
                markus.wM
                markus.wM
                @Mr-Shadi the 1997 doesn't have the reed switch. It has a restricted CDI. Maybe change it for the older 3nc CDI. But you should be getting a lot more than 80kmh. Something else isn't right for sure.
                  Mr ShadiM
                  Mr ShadiM
                  Mr Shadi
                  @markus-w i can hear the spark plug not getting spark when it goes above 80 km/h. But it takes a a little while for it to start not getting spark (3 to 7 seconds). And when i disconnected one of three cdi wire connectors and went on the road to try again. The restrictor sound was different and started right after 80km/h with no delay, unlike if the connector was connected.
                    Hello.
                    Mr ShadiM
                    Mr ShadiM
                    Mr Shadi
                    @Mr-Shadi some pics
                    https://postimg.cc/14GSvH2d cdi
                    https://postimg.cc/KK3SBrtJ colors
                    https://postimg.cc/5Ycc3Y31 colors
                    https://postimg.cc/r05BYVn4 3 cdi wire connectors and 1 other
                    https://postimg.cc/5Q3ZbPMN voltage regulator
                      @Mr-Shadi some pics
                      Mr ShadiM
                      Mr ShadiM
                      Mr Shadi
                      @Mr-Shadi the model is 4BL
                      and its originally from Germany
                        @forum members
                        Isn’t there a later model that needs a CDI wire cutting & earthing somewhere? Or is that a Tzr?…
                        I’m sorry Mr-Shadi, I don’t know too much about later than 1995 model dtr125’s, other than what I have read. What country is your bike from? I’m guessing that english isn’t your first language?
                        I’ll do a bit of reading and try to find out about 1997 bikes…
                        Edit: 4dl Germany! Got it!
                          @forum members
                          This post is deleted!
                            The DTRE has a green and black wire, once earthed that's all the electrical restrictions and then the bike revs off the clocks.
                              I’m worried that he might have the one with the ‘silver box behind the 2T oil tank’ that needs loads of faffing about! I tried getting scrims guide up but kept getting a 401 error!…
                              CalumC Mr ShadiM 2 Replies Last reply
                                @SpookDog 401? That's Unauthorized
                                Right, yeah I don't know about that one. I only really researched the one for my bike.
                                Best thing to do is get a Zeeltronic ignition system for it and you're laughing.
                                S Mr ShadiM 2 Replies Last reply
                                  On a copy (of scrims) on another site it said to install an earlier CDI I think? Yamaha certainly had it in in for you lads with later bikes! Access Forbidden! 😛 SNAFU! ☠️ …
                                  My bad! It was 404 not quite as verboten! 😎 …
                                    Yeah that makes more sense 404 - Not Found. I think you'll find 403 is Forbidden @SpookDog
                                      Mr ShadiM
                                      Mr ShadiM
                                      Mr Shadi
                                      @SpookDog i don't seem to have a silver box behind the oil tank. The only silverish/grayish box is the voltage regulator.
                                        Mr ShadiM
                                        Mr ShadiM
                                        Mr Shadi
                                        @SpookDog scrims sites hosting server has stopped broadcasting the info. But there is a slideshare link on the forum that has the site in slide form
                                          Mr ShadiM
                                          Mr ShadiM
                                          Mr Shadi
                                          @Mr-Shadi on the way back machine, its possible to see the old dt 125 net and other sites but not a lot of info on them
