  3. Welcome New Owners!
  4. DTR
DTR
34 Posts 7 Posters 13.7k Views
  • DTTOLATED Offline
    DTTOLATED Offline
    DTTOLATE
    wrote on last edited by DTTOLATE
    #21
    Cracked it....help yourself to a coconut.
    OllieDTRO 1 Reply Last reply
    • DTTOLATED Offline
      DTTOLATED Offline
      DTTOLATE
      Amazing what a sticker can do 😀
      • DTTOLATED DTTOLATE
        OllieDTRO Offline
        OllieDTRO Offline
        OllieDTR
        @DTTOLATE
        Nice colour scheme mate, Is that aftermarket the rear master cylinder cover?
        • DTTOLATED Offline
          DTTOLATED Offline
          DTTOLATE
          @OllieDTR
          The coffin cover😀 knocked it up myself, used the existing screws holding the cylinder.
            @OllieDTR
            OllieDTRO Offline
            OllieDTRO Offline
            OllieDTR
            @DTTOLATE
            Looks smart I do love custom bits my brother made me some of these chain adjusters
            So much nicer than the OEM steel ones
            What do you think?
            • OllieDTRO OllieDTR
              @DTTOLATE
              What do you think?
              @OllieDTR
              Don’t know about him but I think you should send me a pair to test them out 😀
              • DTTOLATED Offline
                DTTOLATED Offline
                DTTOLATE
                @OllieDTR
                They look the business, its those little details that draw the eye 👍
                  Yeah the chain snails look smart, you can get aluminium ones on eBay for very little money. Needs the internal diameter reaming out mind you.
                  • DTTOLATED Offline
                    DTTOLATED Offline
                    DTTOLATE
                    @SpookDog
                    Hi the honing looks not bad, having to reduce the quality of picture loses the clarity a lot.
                    • DTTOLATED Offline
                      DTTOLATED Offline
                      DTTOLATE
                      @SpookDog
                      Forgeot to ask where's the best place to get the YPVS o rings/seals, I want to carry out a service on it whilst the barrels off.
                        @SpookDog
                        #31
                        @DTTOLATE
                        Barrel I got from PJME waiting for rebuild…
                        It’s not easy getting the light right…
                        Actually, without a bit more definition it’s hard to tell. The real question is whether there’s a piston to fit your bore properly, or whether it’s going to be needing bore/honing again…
                        What does the slack measure?…
                        • DTTOLATED Offline
                          DTTOLATED Offline
                          DTTOLATE
                          @SpookDog
                          I've been told the skirt is the spec area...its snug there, towards the top is the bigger gap due to cylinders being oval and because the heat is greater top end, therefore slightly greater space for expansion.
                          I've just ordered 2 o rings and 1 LH seal from Yambits, I might as well service the power valve whilst the cylinders off. Thanks for your info, its been a good first week on the forum.
                          S OllieDTRO 2 Replies Last reply
                            @SpookDog
                            @DTTOLATE
                            Hey no problem, I’ve learnt that you can’t measure piston clearance with a feeler gauge! I never really looked into it before. I traditionally listen for the clatter 🥴
                              @SpookDog
                              OllieDTRO Offline
                              OllieDTRO Offline
                              OllieDTR
                              wrote on last edited by OllieDTR
                              #34
                              @DTTOLATE
                              You’ll need a very accurate measurement of the bore top middle and bottom, you’ll need for this is a dial bore gauge, it’ll tell you the OD of the bore and tell you how round it is etc etc,
                              I send all my barrels and crank to Jim bailey (roadrunners) and he does it for me, I’ve been using him since 2017 for all my dts and mx bikes rm yz etc anything that has a steel liner which all mine was as they was sleeved, he’s very good and last time he did my dtr barrel I did 11k miles before stripping the bike for a restoration it still ran lovely.
