  3. Welcome New Owners!
  4. DTR
DTR
34 Posts 7 Posters 15.1k Views
  • MadGyverM
    MadGyverM
    Welcome to the forum.It's nice to see the DTR team grow.
    • DTTOLATED
      DTTOLATED
      DTTOLATE
      Thanks Madgyver, I'm hoping to learn more about the bike.
      • DTTOLATED
        DTTOLATED
        DTTOLATE
        wrote on last edited by DTTOLATE
        #21
        Cracked it....help yourself to a coconut.
        OllieDTRO 1 Reply Last reply
        • DTTOLATED
          DTTOLATED
          DTTOLATE
          Amazing what a sticker can do 😀
          • DTTOLATED DTTOLATE
            OllieDTRO
            OllieDTRO
            OllieDTR
            @DTTOLATE
            Nice colour scheme mate, Is that aftermarket the rear master cylinder cover?
            • DTTOLATED
              DTTOLATED
              DTTOLATE
              @OllieDTR
              The coffin cover😀 knocked it up myself, used the existing screws holding the cylinder.
                @OllieDTR
                OllieDTRO
                OllieDTRO
                OllieDTR
                @DTTOLATE
                Looks smart I do love custom bits my brother made me some of these chain adjusters
                So much nicer than the OEM steel ones
                What do you think?
                • OllieDTRO OllieDTR
                  @DTTOLATE
                  What do you think?
                  @OllieDTR
                  Don’t know about him but I think you should send me a pair to test them out 😀
                  • DTTOLATED
                    DTTOLATED
                    DTTOLATE
                    @OllieDTR
                    They look the business, its those little details that draw the eye 👍
                      Yeah the chain snails look smart, you can get aluminium ones on eBay for very little money. Needs the internal diameter reaming out mind you.
                      • DTTOLATED
                        DTTOLATED
                        DTTOLATE
                        Hi the honing looks not bad, having to reduce the quality of picture loses the clarity a lot.
                        • DTTOLATED
                          DTTOLATED
                          DTTOLATE
                          Forgeot to ask where's the best place to get the YPVS o rings/seals, I want to carry out a service on it whilst the barrels off.
                            #31
                            @DTTOLATE
                            Barrel I got from PJME waiting for rebuild…
                            It’s not easy getting the light right…
                            Actually, without a bit more definition it’s hard to tell. The real question is whether there’s a piston to fit your bore properly, or whether it’s going to be needing bore/honing again…
                            What does the slack measure?…
                            • DTTOLATED
                              DTTOLATED
                              DTTOLATE
                              I've been told the skirt is the spec area...its snug there, towards the top is the bigger gap due to cylinders being oval and because the heat is greater top end, therefore slightly greater space for expansion.
                              I've just ordered 2 o rings and 1 LH seal from Yambits, I might as well service the power valve whilst the cylinders off. Thanks for your info, its been a good first week on the forum.
                              S OllieDTRO 2 Replies Last reply
                                @DTTOLATE
                                Hey no problem, I’ve learnt that you can’t measure piston clearance with a feeler gauge! I never really looked into it before. I traditionally listen for the clatter 🥴
                                  OllieDTRO
                                  OllieDTRO
                                  OllieDTR
                                  #34
                                  @DTTOLATE
                                  You’ll need a very accurate measurement of the bore top middle and bottom, you’ll need for this is a dial bore gauge, it’ll tell you the OD of the bore and tell you how round it is etc etc,
                                  I send all my barrels and crank to Jim bailey (roadrunners) and he does it for me, I’ve been using him since 2017 for all my dts and mx bikes rm yz etc anything that has a steel liner which all mine was as they was sleeved, he’s very good and last time he did my dtr barrel I did 11k miles before stripping the bike for a restoration it still ran lovely.
