  3. Welcome New Owners!
  4. DTR
DTR
34 Posts 7 Posters 14.7k Views
  • DTTOLATED
    DTTOLATED
    DTTOLATE
    Spookdog thanks for the reply, I'm currently trying to suss this posting pics, I'll get some up when or if I can.
    • DTTOLATED DTTOLATE
      @DTTOLATE
      Download Imgur and use it to post/host the pic. Then copy the link and post it here using the 3rd icon from left in the toolbar…
      • DTTOLATED
        DTTOLATED
        DTTOLATE
        Most of my stuffs in dropbox, if I copied a link would that do the trick?
          @DTTOLATE
          Don’t know what that is!
          Try it 🙂
          As long as it’s being hosted somewhere on the web
          • DTTOLATED
            DTTOLATED
            DTTOLATE
            • MadGyverM
              MadGyverM
              Welcome to the forum.It's nice to see the DTR team grow.
              • DTTOLATED
                DTTOLATED
                DTTOLATE
                Thanks Madgyver, I'm hoping to learn more about the bike.
                • DTTOLATED
                  DTTOLATED
                  DTTOLATE
                  wrote on last edited by DTTOLATE
                  #21
                  Cracked it....help yourself to a coconut.
                  OllieDTRO 1 Reply Last reply
                  • DTTOLATED
                    DTTOLATED
                    DTTOLATE
                    Amazing what a sticker can do 😀
                      OllieDTRO
                      OllieDTRO
                      OllieDTR
                      @DTTOLATE
                      Nice colour scheme mate, Is that aftermarket the rear master cylinder cover?
                      • DTTOLATED
                        DTTOLATED
                        DTTOLATE
                        @OllieDTR
                        The coffin cover😀 knocked it up myself, used the existing screws holding the cylinder.
                          @OllieDTR
                          OllieDTRO
                          OllieDTRO
                          OllieDTR
                          @DTTOLATE
                          Looks smart I do love custom bits my brother made me some of these chain adjusters
                          So much nicer than the OEM steel ones
                          What do you think?
                          • OllieDTRO OllieDTR
                            @DTTOLATE
                            What do you think?
                            @OllieDTR
                            Don’t know about him but I think you should send me a pair to test them out 😀
                            • DTTOLATED
                              DTTOLATED
                              DTTOLATE
                              @OllieDTR
                              They look the business, its those little details that draw the eye 👍
                                Yeah the chain snails look smart, you can get aluminium ones on eBay for very little money. Needs the internal diameter reaming out mind you.
                                • DTTOLATED
                                  DTTOLATED
                                  DTTOLATE
                                  Hi the honing looks not bad, having to reduce the quality of picture loses the clarity a lot.
                                  • DTTOLATED
                                    DTTOLATED
                                    DTTOLATE
                                    Forgeot to ask where's the best place to get the YPVS o rings/seals, I want to carry out a service on it whilst the barrels off.
                                      #31
                                      @DTTOLATE
                                      Barrel I got from PJME waiting for rebuild…
                                      It’s not easy getting the light right…
                                      Actually, without a bit more definition it’s hard to tell. The real question is whether there’s a piston to fit your bore properly, or whether it’s going to be needing bore/honing again…
                                      What does the slack measure?…
                                      • DTTOLATED
                                        DTTOLATED
                                        DTTOLATE
                                        I've been told the skirt is the spec area...its snug there, towards the top is the bigger gap due to cylinders being oval and because the heat is greater top end, therefore slightly greater space for expansion.
                                        I've just ordered 2 o rings and 1 LH seal from Yambits, I might as well service the power valve whilst the cylinders off. Thanks for your info, its been a good first week on the forum.
                                        S OllieDTRO 2 Replies Last reply
                                          @DTTOLATE
                                          Hey no problem, I’ve learnt that you can’t measure piston clearance with a feeler gauge! I never really looked into it before. I traditionally listen for the clatter 🥴
