  3. Twin rad
Twin rad
21 Posts 8 Posters 7.5k Views 1 Watching
  • G
    G
    gareth_iowc
    Any suggestions on what to use for a twin rad setup on the dt?
    Thanks
    DT125R 2000
    DRZ400 2006
    Golf Mk3 20v Turbo 1996
      Dt230 for dtr the Lanza is near straight swap on the re just needs one bracket made up. I have only done the Lanza conversion. There was zero noticeable gains. Ran hotter if anything. Be nicer to have some ally rads.
      • F
        F
        The engine ran hotter or the rad temp was higher?
        • G
          G
          gareth_iowc
          Awesome thanks.
          Only reason was with the yz engine i no longer need the oil tank and that leaves a massive gap. Not sure what todo ATM. The Lanza rad appears to be a rare beast.
          DT125R 2000
          DRZ400 2006
          • Louis-DT-WRL
            Louis-DT-WRL
            Louis-DT-WR
            Dt200r parts
            • MightymanM
              MightymanM
              If you don't need it, you could always save the extra weight 😉
              • DartyD
                DartyD
                YZ 1989-96 rad? WR200 filler side rad is a good upgrade? Chunky core in the them
                  The engine ran hotter with a Lanza rad. The second rad was purely a gimmick for me. It's got a tiny core and capacity. Doubt it actually cools the engine.
                  • G gareth_iowc
                    Thanks
                    @gareth_iowc There's some decent ali rads to be found on ebay dude.
                    • ZrakoZ
                      ZrakoZ
                      Zrako
                      wrote on last edited by Zrako
                      I like these , looks strong enough even without frame but Im afraid about the clearance between expansion chamber, tank etc...
                      http://www.ebay.co.uk/itm/152190539528
                      Having these in watchlist for some time...
                      1979 Jawa Mustang 50
                      2003 Gilera DNA 125 R.I.P
                      2015 Keeway TX 125 SM
                      2006 Yamaha DT 125 X
                      • G
                        G
                        gareth_iowc
                        That's what I tried to fit. At the top of both rads there is an outlet to join them. On the yz there is a gape in the frame but on the dt there is not. I didn't fancy drilling the frame.
                        DT125R 2000
                        DRZ400 2006
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          Louis-DT-WR
                          I have a r/h radiator from a Dt200r. Reasonable condition bit someone painted it dark blue. Doubt there is much benefit from it because it's capacity is tiny
                          • ZrakoZ Zrako
                            @Zrako Yeah but that is on my brothers YZ?
                            ZrakoZ 1 Reply Last reply
                              ZrakoZ
                              ZrakoZ
                              Zrako
                              @Calum I dont know , found the pic on google. Might be
                              • ZrakoZ Zrako
                                @Zrako No, lol, that is my brothers YZ.
                                  ZrakoZ
                                  ZrakoZ
                                  Zrako
                                  @Calum cool mate , will be great to make a tutorial for us how to fit them on the dt 😂 Just when he not looking take them off 😂
                                  MightymanM 1 Reply Last reply
                                  • ZrakoZ Zrako
                                    MightymanM
                                    MightymanM
                                    @Zrako, @gareth_iowc already mentioned why they won't fit without modification to the frame. That picture you showed is Calums brother YZ.. nothing to do with the DT.
                                    • NINJAN
                                      @gareth_iowc Just get a big fat ali one dude, Yamaha spent millions designing the bike, if they decided that a single rad was all that was required, then who are we too argue??? 😉
                                        @CYBER-NINJA They also made the bike to a budget. So it is possible to improve the bike in areas
                                          @Calum Very true, but you have already stated that having a second rad has not improved the engine cooling, so why go through all the hassle if it's not gonna make much of an improvement???
