  3. Twin rad
Twin rad
21 Posts 8 Posters 7.6k Views 1 Watching
    Dt230 for dtr the Lanza is near straight swap on the re just needs one bracket made up. I have only done the Lanza conversion. There was zero noticeable gains. Ran hotter if anything. Be nicer to have some ally rads.
    • F
      The engine ran hotter or the rad temp was higher?
      • G
        G
        gareth_iowc
        Awesome thanks.
        Only reason was with the yz engine i no longer need the oil tank and that leaves a massive gap. Not sure what todo ATM. The Lanza rad appears to be a rare beast.
        DT125R 2000
        DRZ400 2006
        Golf Mk3 20v Turbo 1996
        • Louis-DT-WRL
          Louis-DT-WRL
          Dt200r parts
          • MightymanM
            If you don't need it, you could always save the extra weight 😉
              YZ 1989-96 rad? WR200 filler side rad is a good upgrade? Chunky core in the them
                The engine ran hotter with a Lanza rad. The second rad was purely a gimmick for me. It's got a tiny core and capacity. Doubt it actually cools the engine.
                • G gareth_iowc
                  Any suggestions on what to use for a twin rad setup on the dt?
                  Thanks
                  @gareth_iowc There's some decent ali rads to be found on ebay dude.
                  • ZrakoZ
                    ZrakoZ
                    Zrako
                    wrote on last edited by Zrako
                    I like these , looks strong enough even without frame but Im afraid about the clearance between expansion chamber, tank etc...
                    http://www.ebay.co.uk/itm/152190539528
                    Having these in watchlist for some time...
                    1979 Jawa Mustang 50
                    2003 Gilera DNA 125 R.I.P
                    2015 Keeway TX 125 SM
                    2006 Yamaha DT 125 X
                    • G
                      G
                      gareth_iowc
                      That's what I tried to fit. At the top of both rads there is an outlet to join them. On the yz there is a gape in the frame but on the dt there is not. I didn't fancy drilling the frame.
                      DT125R 2000
                      DRZ400 2006
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        I have a r/h radiator from a Dt200r. Reasonable condition bit someone painted it dark blue. Doubt there is much benefit from it because it's capacity is tiny
                        • ZrakoZ Zrako
                          @Zrako Yeah but that is on my brothers YZ?
                          ZrakoZ 1 Reply Last reply
                            ZrakoZ
                            ZrakoZ
                            Zrako
                            @Calum I dont know , found the pic on google. Might be
                            • ZrakoZ Zrako
                              @Zrako No, lol, that is my brothers YZ.
                                ZrakoZ
                                ZrakoZ
                                Zrako
                                @Calum cool mate , will be great to make a tutorial for us how to fit them on the dt 😂 Just when he not looking take them off 😂
                                MightymanM 1 Reply Last reply
                                • ZrakoZ Zrako
                                  @Zrako, @gareth_iowc already mentioned why they won't fit without modification to the frame. That picture you showed is Calums brother YZ.. nothing to do with the DT.
                                  • NINJAN
                                    @gareth_iowc Just get a big fat ali one dude, Yamaha spent millions designing the bike, if they decided that a single rad was all that was required, then who are we too argue??? 😉
                                      @CYBER-NINJA They also made the bike to a budget. So it is possible to improve the bike in areas
                                        @Calum Very true, but you have already stated that having a second rad has not improved the engine cooling, so why go through all the hassle if it's not gonna make much of an improvement???
                                          @CYBER-NINJA An ally rad would make a huge difference. The Lanza rad, like the DT200R Rad, has a tiny capacity. I'm sure it ran very hot. But then the DT never had a digital temperature gauge to compare it to. The RE's Simply have a light that goes on when the engine is too hot.
