  4. Power valve
Power valve
31 Posts 11 Posters 13.1k Views
  • V vtrn_raptor
    Well I've took the servo and everything off made sure wasn't over tight then plugged back it but does the cleaning cycle really fast and doesn't move at all with the bike on any ideas
    F Offline
    F Offline
    @vtrn_raptor it won't move until you start to rev the bike mate. I think it starts to open up around 6000rpm
    • ijohney123I Offline
      ijohney123I Offline
      ijohney123
      How manys wires is your servo
      • V Offline
        V Offline
        vtrn_raptor
        5 wires mate and it didn't budge at all even up to 7k
        ijohney123I CalumC 2 Replies Last reply
        • V vtrn_raptor
          ijohney123I Offline
          ijohney123I Offline
          ijohney123
          @vtrn_raptor servo dodgy ?
          Do u have another cdi unit on yours to control it.?
          • V Offline
            V Offline
            vtrn_raptor
            Yeah it's all connected to the cdi I've ordered a new servo see if that helps if not then it's the cdi
            • V vtrn_raptor
              @vtrn_raptor Yeah it won't, I don't think it does at all in neutral.
              It's easy to tell if the servo is operated as it will pull right through the rev range.
              • V Offline
                V Offline
                vtrn_raptor
                It doesn't move at all and the cleaning cycle is really erratic
                • V vtrn_raptor
                  @vtrn_raptor Bad battery can do that. Also if it isn't setup the correct way, i.e. the cables the wrog way round.
                  • V Offline
                    V Offline
                    vtrn_raptor
                    The cables are the right way round I followed a Haynes manual the servos exactly the same without cables connected so ima try the new servo then battery if not either I'll replace the cdi bike was pinned via the servo and could be the reason it was pinned in the first place
                    • T Offline
                      T Offline
                      thechompster
                      Any news on this thread? Did the new servo sort it as mine does the same thing.
                      • T thechompster
                        Old thread alert, but! My servo was doing this when I used inferior 2stroke oil and the power valve was gummed up and sticky. As soon as I cleaned of the varnish/gumpf it operated sweet and smooth…
