  4. Power valve
Power valve
31 Posts 11 Posters 13.0k Views
  • V Offline
    V Offline
    vtrn_raptor
    What's better power wise pinned or servo as my bikes pinned but I have no idea how so just curious what give more power
    • F Offline
      F Offline
      No difference in peak power, but using the servo you'll get a broader range, so you'll have better low and mid range. Obviously it depends on exactly where you've pinned your power valve
      • V Offline
        V Offline
        vtrn_raptor
        I have no idea as it was like it when I got the bike but the servo is still their and all the cable connections to the power valve are attached but the servo is unplugged
        • F Offline
          F Offline
          Mine was pinned when i bought the bike, reinstating the servo etc made a huge difference for me
          ijohney123I 1 Reply Last reply
            Pinned all the way. You gain everything and lose nothing.
            Unless your CDI is restricted, that'll cause the valve to shut after a certain RPM.
            Zeeltronic gives you complete control of when the valve opens and shuts, allowing you to really get the full potential of the YPVS. Big gains to be made with a custom ignition.
            • V Offline
              V Offline
              vtrn_raptor
              So keeping it pinned is better
              • D Offline
                dan28
                I would try it with the servo when it's pinned there is no power at low revs
                Perhaps it's unplugged for a reason I would take the pv out an clean it toke sure it's not sticking then connect the servo up an try it
                • V vtrn_raptor
                  @vtrn_raptor Jeez I really messed that up. Sorry no, Servo all the way.
                  Don't pin use the servo. I don't know why I said pinned sorry.
                  Servo is much better.
                  • J Offline
                    J Offline
                    Jens Eskildsen
                    Servo for sure, best of both worlds.
                    • V Offline
                      V Offline
                      vtrn_raptor
                      I would but I have no idea how it's been pinned took off the cover on the left side and all the cables to the pulley are still connected so I'm really confused lol
                      MightymanM 1 Reply Last reply
                      • V vtrn_raptor
                        MightymanM Offline
                        MightymanM Offline
                        @vtrn_raptor can you hear it trying to do it's cycle when you turn your bikes ignition on?
                        • V Offline
                          V Offline
                          vtrn_raptor
                          Not sure I'll check when I'll plug it all in and check when I'm home
                          • CallumJ94C Offline
                            CallumJ94C Offline
                            CallumJ94
                            Sorry to butt in the thread, but has anyone got any idea why... when I connected up a working servo to the plugs it was completely dead? No cleaning cycle whatsoever, cables not connected so no load on it. Just not working at all. What's the most likely causes? Could it be a CDI issue? (03 DTR) I want to put a servo on desperately. Cheers.
                              Yeah motor can be dead, or faulty cdi.
                              Multi meter on the plugs will tell you.
                              • F finnerz89
                                ijohney123I Offline
                                ijohney123I Offline
                                ijohney123
                                @finnerz89 how did you manage to wire servo up pal
                                F 1 Reply Last reply
                                • ZrakoZ Offline
                                  ZrakoZ Offline
                                  Zrako
                                  Or overtightened servo tensioners . I was setting them on and if they are not set properly , the servo will not reset when ignition turned on
                                  1979 Jawa Mustang 50
                                  2003 Gilera DNA 125 R.I.P
                                  2015 Keeway TX 125 SM
                                  2006 Yamaha DT 125 X
                                  • ZrakoZ Zrako
                                    ijohney123I Offline
                                    ijohney123I Offline
                                    ijohney123
                                    @Zrako have you not had to rewire servo ?
                                    • ijohney123I ijohney123
                                      F Offline
                                      F Offline
                                      @ijohney123 just plug and play mate. My servo was unplugged with the cables overtightened so the pulley didn't move
                                      • ZrakoZ Offline
                                        ZrakoZ Offline
                                        Zrako
                                        No , I had a good conectors on bike so when Im rebuilt it was just plug out - plug in . Try to loose the tensioners a bit . There is a "how to" in haynes manual 0_1492858857458_14928588372441878779145.jpg
                                        • V Offline
                                          V Offline
                                          vtrn_raptor
                                          Well I've took the servo and everything off made sure wasn't over tight then plugged back it but does the cleaning cycle really fast and doesn't move at all with the bike on any ideas
