  4. Power valve
Power valve
31 Posts 11 Posters 14.3k Views
  • D
    dan28
    I would try it with the servo when it's pinned there is no power at low revs
    Perhaps it's unplugged for a reason I would take the pv out an clean it toke sure it's not sticking then connect the servo up an try it
    • V vtrn_raptor
      So keeping it pinned is better
      @vtrn_raptor Jeez I really messed that up. Sorry no, Servo all the way.
      Don't pin use the servo. I don't know why I said pinned sorry.
      Servo is much better.
        Servo for sure, best of both worlds.
        • V
          V
          vtrn_raptor
          I would but I have no idea how it's been pinned took off the cover on the left side and all the cables to the pulley are still connected so I'm really confused lol
          MightymanM 1 Reply Last reply
          • V vtrn_raptor
            @vtrn_raptor can you hear it trying to do it's cycle when you turn your bikes ignition on?
            • V
              V
              vtrn_raptor
              Not sure I'll check when I'll plug it all in and check when I'm home
              • CallumJ94C
                CallumJ94C
                CallumJ94
                Sorry to butt in the thread, but has anyone got any idea why... when I connected up a working servo to the plugs it was completely dead? No cleaning cycle whatsoever, cables not connected so no load on it. Just not working at all. What's the most likely causes? Could it be a CDI issue? (03 DTR) I want to put a servo on desperately. Cheers.
                  Yeah motor can be dead, or faulty cdi.
                  Multi meter on the plugs will tell you.
                    Mine was pinned when i bought the bike, reinstating the servo etc made a huge difference for me
                    ijohney123I
                    ijohney123I
                    ijohney123
                    @finnerz89 how did you manage to wire servo up pal
                    F 1 Reply Last reply
                    • ZrakoZ
                      ZrakoZ
                      Zrako
                      Or overtightened servo tensioners . I was setting them on and if they are not set properly , the servo will not reset when ignition turned on
                      1979 Jawa Mustang 50
                      2003 Gilera DNA 125 R.I.P
                      2015 Keeway TX 125 SM
                      2006 Yamaha DT 125 X
                      ijohney123I 1 Reply Last reply
                      • ZrakoZ Zrako
                        ijohney123I
                        ijohney123I
                        ijohney123
                        @Zrako have you not had to rewire servo ?
                        • ijohney123I ijohney123
                          @ijohney123 just plug and play mate. My servo was unplugged with the cables overtightened so the pulley didn't move
                          • ZrakoZ
                            ZrakoZ
                            Zrako
                            No , I had a good conectors on bike so when Im rebuilt it was just plug out - plug in . Try to loose the tensioners a bit . There is a "how to" in haynes manual 0_1492858857458_14928588372441878779145.jpg
                            • V
                              V
                              vtrn_raptor
                              Well I've took the servo and everything off made sure wasn't over tight then plugged back it but does the cleaning cycle really fast and doesn't move at all with the bike on any ideas
                              • V vtrn_raptor
                                @vtrn_raptor it won't move until you start to rev the bike mate. I think it starts to open up around 6000rpm
                                • ijohney123I
                                  ijohney123I
                                  ijohney123
                                  How manys wires is your servo
                                  • V
                                    V
                                    vtrn_raptor
                                    5 wires mate and it didn't budge at all even up to 7k
                                    ijohney123I CalumC 2 Replies Last reply
                                    • V vtrn_raptor
                                      ijohney123I
                                      ijohney123I
                                      ijohney123
                                      @vtrn_raptor servo dodgy ?
                                      Do u have another cdi unit on yours to control it.?
                                      • V
                                        V
                                        vtrn_raptor
                                        Yeah it's all connected to the cdi I've ordered a new servo see if that helps if not then it's the cdi
                                        • V vtrn_raptor
                                          @vtrn_raptor Yeah it won't, I don't think it does at all in neutral.
                                          It's easy to tell if the servo is operated as it will pull right through the rev range.
