  4. Power valve
Power valve
31 Posts 11 Posters 14.3k Views
    Mine was pinned when i bought the bike, reinstating the servo etc made a huge difference for me
    ijohney123I
    ijohney123I
    ijohney123
    @finnerz89 how did you manage to wire servo up pal
    F 1 Reply Last reply
    • ZrakoZ
      ZrakoZ
      Zrako
      Or overtightened servo tensioners . I was setting them on and if they are not set properly , the servo will not reset when ignition turned on
      1979 Jawa Mustang 50
      2003 Gilera DNA 125 R.I.P
      2015 Keeway TX 125 SM
      2006 Yamaha DT 125 X
      ijohney123I 1 Reply Last reply
      • ZrakoZ Zrako
        ijohney123I
        ijohney123I
        ijohney123
        @Zrako have you not had to rewire servo ?
        • ijohney123I ijohney123
          @ijohney123 just plug and play mate. My servo was unplugged with the cables overtightened so the pulley didn't move
          • ZrakoZ
            ZrakoZ
            Zrako
            No , I had a good conectors on bike so when Im rebuilt it was just plug out - plug in . Try to loose the tensioners a bit . There is a "how to" in haynes manual 0_1492858857458_14928588372441878779145.jpg
            • V
              V
              vtrn_raptor
              Well I've took the servo and everything off made sure wasn't over tight then plugged back it but does the cleaning cycle really fast and doesn't move at all with the bike on any ideas
              • V vtrn_raptor
                @vtrn_raptor it won't move until you start to rev the bike mate. I think it starts to open up around 6000rpm
                • ijohney123I
                  ijohney123I
                  ijohney123
                  How manys wires is your servo
                  • V
                    V
                    vtrn_raptor
                    5 wires mate and it didn't budge at all even up to 7k
                    ijohney123I CalumC 2 Replies Last reply
                    • V vtrn_raptor
                      ijohney123I
                      ijohney123I
                      ijohney123
                      @vtrn_raptor servo dodgy ?
                      Do u have another cdi unit on yours to control it.?
                      • V
                        V
                        vtrn_raptor
                        Yeah it's all connected to the cdi I've ordered a new servo see if that helps if not then it's the cdi
                        • V vtrn_raptor
                          @vtrn_raptor Yeah it won't, I don't think it does at all in neutral.
                          It's easy to tell if the servo is operated as it will pull right through the rev range.
                          • V
                            V
                            vtrn_raptor
                            It doesn't move at all and the cleaning cycle is really erratic
                            • V vtrn_raptor
                              @vtrn_raptor Bad battery can do that. Also if it isn't setup the correct way, i.e. the cables the wrog way round.
                              • V
                                V
                                vtrn_raptor
                                The cables are the right way round I followed a Haynes manual the servos exactly the same without cables connected so ima try the new servo then battery if not either I'll replace the cdi bike was pinned via the servo and could be the reason it was pinned in the first place
                                • T
                                  T
                                  thechompster
                                  Any news on this thread? Did the new servo sort it as mine does the same thing.
                                  • T thechompster
                                    Old thread alert, but! My servo was doing this when I used inferior 2stroke oil and the power valve was gummed up and sticky. As soon as I cleaned of the varnish/gumpf it operated sweet and smooth…
