  4. DT 125 R '88... New project
89 Posts 11 Posters 34.7k Views 1 Watching
    Yeah that's looking smart.
    • MightymanM Offline
      MightymanM Offline
      You swapping to new graphics? The current ones you have are awsome!
      • J Offline
        J Offline
        jgr72
        I'm only changing that are broken or worn... And will replace them to exactly original.
        MightymanM 1 Reply Last reply
        • J jgr72
          MightymanM Offline
          MightymanM Offline
          @jgr72 nice 👍
          • J Offline
            J Offline
            jgr72
            Few days ago I changed original snorkel to an DT230 Lanza version... Few decals arrived also from ebay... Not changing them now... later... maybe during winter... If I decide to take the bike in parts and do some painting to body and rear swing...
            Been sitting in google for hours and days 😄 ... searching for something fun:
            maybe I will change Gianelli exhaust, Athena 170cc cyl kit and mikuni TM30 carburetor during winter... Those shoud give me more pleasure to ride 🙂 And still keep original look... Need to work hard to make the money for that 😄 😄 😄
            • J Offline
              J Offline
              jgr72
              A little update... Today I fixed front brake... Sealing was worn, and it would be only matter of time, when the brake cylinder would stuck totally... It was already a bit lazy I think... I did it just in time, there ware some corrosion in brake caliper, but I used sand paper and decide that it's still useful... Piston was in excellent condition... Old brake fluid was quite black and shitty... perhaps original and nearly 30 years old? Then caliper rebuild with new sealing and gasket... Tomorrow I have to bleed air away from the system... It looks like I have to use pressured air to force brake fluid into caliper... Brake lever is now doing nothing 😄 Sorry that I was too lazy to take any photos...
              I found myself from ordering a new carb... Mikuni TM30... and it's on the way already 😛 And earlier I also ordered DT230 Lanza version of carburetor -> air box joint... Lanza item should be direct fit to TM30 carb and maybe some minor modification to the original air box... On the engine side, the diameter difference (VM28 vs TM30) is only 1mm bigger, I assume it will fit to the original intake rubber... TM30 is also 5mm longer, but that shouldn't be any problem...
              Anyone have idea for right main jet? 160? 170? 180?
              Silocone tubes arrived yesterday, I will replace all 2-stroke oil feed tubes from oiltank, to carb...
              • J Offline
                J Offline
                jgr72
                Today I changed leaking autolube hoses to a silicone one... I ordered them from ebay many weeks ago and they arrived few days ago... It was an easy job to do. Tank to autolube pump hose was nice fit with 5mm silicone hose. Autolube pump to carb was nice fit with 3mm hose. But be aware if you bleed whole pump empty, it might not be able to suck oil from tank!!! Be careful when you start the engine!!! I have to squirt oil direct in to the pump and open air screw in order to get the air out from the pump. Here are from photos from that job...
                Dissolution:
                Pump to carb hose size:
                Tank to pump hose:
                Pump to carb hose in place:
                Tank to pump hose in place:
                Ready to ride:
                • J jgr72
                  Dissolution:
                  Tank to pump hose:
                  Ready to ride:
                  @jgr72 Nice clear lionesis what I like to see.
                  Keeping an eye on that oil 😉
                  • J Offline
                    J Offline
                    jgr72
                    wrote on last edited by jgr72
                    #29
                    Yeah, actually it was nice to see how the oil travels in pump to carb hose... I had red oil and air in that hose, and it travels with a rythm 💃 And it was easy to see how it works when you rev the engine...
                      MightymanM Offline
                      Very nice, hopefully others can come across this thread if they want to swap their own hoses out for clear ones. 👍
                      • J Offline
                        J Offline
                        jgr72
                        Thats why I took those photos! Internet is a information source 🙂
                        • J Offline
                          J Offline
                          jgr72
                          Santa Claus came early this year 🙂 I received TM30 & 230 Lanza air joint in a same day 🙂 It's a great match with those two! Let's see later how it will fit into DT125R airbox 😄 Sadly I don't have any main jets between 150 and 200 range... I've been told that 170 might be right main jet to start from... Also need to drill a hole to the TM30 for oil feed anyway, and don't have that hose nose yet... I'll come later on with pics when I'm installing that... Here are some pictures of todays treasure:
                          Yamaha DT 230 Lanza carburetor -> air box joint:
                          It a great match together:
                          • J jgr72
                            @jgr72 Looking good buddy!
                            • A Offline
                              A Offline
                              andrewj1680
                              How did this setup workout for you?
                              • J Offline
                                J Offline
                                jgr72
                                Actually I haven't tried it yet... But it supposed to be a good setup!? Original carb feels a bit out of right setup... It feels rich in mid rev and it won't rev above 8k... top speed is hardly 110km/h. But I have no intention to do anything for it... new carb is only waiting to "step in" 😄
                                Still waiting for that oil hose nose from ebay... It's taking many weeks from china to europe sometimes... Meanwhile I had to do something... I drilled a 2.5mm hole for oil feed hose nose and tapped M3 threads with a screw drive style handle... M3 is so small and alu so soft that it was an easy to turn...
                                • J Offline
                                  J Offline
                                  jgr72
                                  Finally hose noses arrived:
                                  I bought few of them in case I need one in future...
                                  There it is... I also added some "thread glue":
                                  alt text/20170704_092559.jpg)
                                  Okey, now I have all I need to change the carb. But how about the carb throttle cable? Is it a straight swap, or do I have to make some modifications? I've been trying to find answers from google...
                                  • J jgr72
                                    @jgr72 it should fit but the only way to know for sure is to actually try it
                                      For my dellorto VHSA carb the cable needed modifying.
                                      • J Offline
                                        J Offline
                                        jgr72
                                        #39
                                        Yes, it fits, but I need to strip throttle cable about 30mm... Sorry that my phone focus to the engine, and not the cable 😄 :
                                        But there it is now:
                                        TM30 comes quite close to clutch, it can't be installed straight... must be a little bit askew... Maybe some other intake would give better position?:
                                        Next problem is this:
                                        It wouldn't line up nice... Maybe DT230 Lanza intake would correct this problem?
                                        Or then I just make my own boot for universal air filter, and forget the whole original airbox... I tried the bike without air filter and it runs quite nice, no torque loss at low rpm, and still have more power at high rpm... feels good, even I might not have the best jetting setup jet... If I remember right, the best main jet was 135 etc...
                                        But... I can't ride without an air filter, and I need to fine some solution that I can ride with while I'm planning my next move:
                                        I sprayed urethane, and "glued" 50mm alu pipe to the air box 😄 This wasn't a very professional style, but its easy to remove and airbox is still original, while I don't know what to do next 😄
                                        • J jgr72
                                          @jgr72 You are running a 3BN barrel.
                                          They have slightly shorter strokes with bigger bores than the classic 3MB. Be mindful of that when it comes to engine rebuild time.
