  4. DT125R 1994 Running Project
65 Posts 7 Posters 20.8k Views 1 Watching
  • O
    O
    The one on the 89 bike did not line up correctly either, had to adjust rear bracket on expansion pipe to obtain correct alignment, otherwise silencer disappeared under rear mudguard and connection to cylinder twisted
    terry.tzT 1 Reply Last reply
    • O oldman
      terry.tzT
      terry.tzT
      terry.tz
      @oldman ye mine was trying to disappear under the rear fender but it's on snug, for now, il redo the brackets myself when I'm ready to start rebuilding her I have access to a welder so no problems @Calum ye il get some pics up bike still looking rough well is rough lol il take pics of the brackets too
      • terry.tzT
        terry.tzT
        terry.tz
        wrote on last edited by terry.tz
        #43
        rebuilt the carb last night still not rebuilt to perfection far from it some screws were f!cked I replaced what I could il need to get some new ones ideally but the screws I put back on are good there was no gasket for the front of the carb and mine is knackered its sitting ok though ill replace when I do it fully with new screws etc the rebuild kit came with a different needle to the original I eyed them up and the highest setting was equal to the second from bottom that mine was on taper was different to couldn't see the main jet size I had 210 and 225 I put 210 in its now fitted and seems to be running fine might be a bit lean but its reving cleanly all the way through so it seems anyway gonna take it for a run later and see what the plug tells me and if my problem at high revs has been solved
        Glynn123G 1 Reply Last reply
        • terry.tzT terry.tz
          Glynn123G
          Glynn123G
          Glynn123
          @terry-tz you'll want atleast a 230-240 main with Romeu pipe mate, I run a 250, but have snorkel removed from airbox.
          • terry.tzT
            terry.tzT
            terry.tz
            #45
            @Glynn123 ill see how she runs first but think ill be putting that 225 in but she runs good
            • terry.tzT
              terry.tzT
              terry.tz
                @terry-tz was that wide open throttle ? Looks a tad rich to me.
                  terry.tzT
                  terry.tzT
                  terry.tz
                  @calum bare in mind its a used plug pretty new though and was in a bit ricker state mainly wide open hangs I tad in the middle think I might be a tad rich on the needle or the taper's not that great
                    I would rather err on the side of tad rich than lean lol.
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      any suggestions I'm still having problems with what I thought was full throttle when I'm in 5 gear it bogs seems to be any throttle now before I cleaned the carb it was funny in all gears and 3/4 plus throttle I no there very different symptoms but I'm very sure its the same problem
                        terry.tzT
                        terry.tzT
                        terry.tz
                        @calum ye me to but it's hanging a bit too much but I'm going to wait to see what the plugs like in a few days and try to solve my other problem first
                        • Glynn123G Glynn123
                          @glynn123 is that the same for other pipes I have a 210 with a full exhaust
                          Glynn123G terry.tzT 2 Replies Last reply
                            Glynn123G
                            Glynn123G
                            Glynn123
                            @declan yeah mate, usually they like a 240 on a full system, I know mine was definetely way lean when it had a 210
                              @glynn123 Funny, my DEP was sound on 210 main. It was actually when I fitted a Wøssner Piston did I find jetting an issue, think I needed 280 main in the end to get the jetting sorted. It should be done a bike per bike basis ideally.
                              terry.tzT Glynn123G 2 Replies Last reply
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @declan just see what you plug says
                                  terry.tzT
                                  terry.tzT
                                  terry.tz
                                  @calum wow 210 to a 280 that's some big jump how did the performance change
                                    @terry-tz I can't say I noticed a change when I upjetted it, it was purely to get it to not bog out.
                                    Bit difference with a DEP pipe though.
                                      Glynn123G
                                      Glynn123G
                                      Glynn123
                                      @calum that's weird, I'm running a wossner piston with 250 main, but I suppose you run open filter rather than airbox don't you?
                                        terry.tzT
                                        terry.tzT
                                        terry.tz
                                        @calum fair enough
                                          @glynn123 This was way back when. I may have ran the 3MBP barrel. But whatever it was, I was having difficulty getting the jetting spot on.
