  4. Clutch
Clutch
14 Posts 6 Posters 3.7k Views 1 Watching
  • RickyR Offline
    RickyR Offline
    Ricky
    Hi guys coming home from work my dtx 2005 started giving me trouble when pulling up to lights and down gear to neutral sometimes it won't go into first until I release the clutch and pull it back in any idea what it could be thanks
    DT 125X
    • MightymanM Offline
      MightymanM Offline
      I get this all the time. It's one of those problems I just live with. Not even sure if it's an actual issue with the bike, or just a side effect of having a manual gearbox that was designed more than 20 years ago..
      I could be wrong, but I think generally the output shaft should be rotating slightly in order for you to change gear, so when you pull up to a stop, your output shaft / front sprocket is no longer rotating if you are in neutral, and so it may be a little harder to change gear.
      • declanD Offline
        Yeah I too have this way to beat it is to shift into first before you come to a dead stop and my brand new bikes have also done this so I don't think it's a problem
        • F Offline
          F Offline
          It's not a problem, just a side effect of constant mesh gearboxes.
          My triumph does it
          • RickyR Offline
            RickyR Offline
            Ricky
            Cheers guys just a bit worried as it never use to do it and once I let go of the clutch and pull it back in it goes in gear no problem
            DT 125X
            • F Offline
              F Offline
              I'd check the adjustment of the clutch lever just to be sure, but I think you'll be fine
              Have you tried blipping the throttle when going down the box? Might make it a bit smoother
              • RickyR Ricky
                @ricky ahhhh you had to start a thread about clutches didn't you my clutch cable just snapped lol
                  @declan only buy OEM clutch cables. Aftefmarket ones are useless.
                    @calum thanks for that matey just brought one it's the same as the other one it looks as if the lever I brought cut through the cable due to a bad design
                    • D Offline
                      DragonY2k
                      i think my clutch needs adjusted ive really gotta pull the lever all the way in to engage the clutch and put it into 1st etc etc ....probably just an adjustment
                      • D DragonY2k
                        @dragony2k how's the free play
                        • D Offline
                          DragonY2k
                          lever still feels tight ....no real play as such
                          • D DragonY2k
                            @dragony2k there's your problem get some slack on the cable that will give you a bigger bite point
                              @declan you say tight as a good thing? It really isn't you will be burning your clutch up
