  4. Need help
Need help
167 Posts 11 Posters 97.4k Views
  • V Offline
    V Offline
    vtrn_raptor
    Idles fine until giving throttle will gradually build up to 6k and even past it but does what happens in the vid if you give it full throttle with choke on it dies instantly but will start with it on but have to turn it off usually starts first kick from cold I'll take the snorkel off in a sec and give it a go
    F 1 Reply Last reply
    • terry.tzT Offline
      terry.tzT Offline
      terry.tz
      what it idle at
      • V Offline
        V Offline
        vtrn_raptor
        Around 1.5-2k
        terry.tzT 1 Reply Last reply
        • V vtrn_raptor
          Around 1.5-2k
          terry.tzT Offline
          terry.tzT Offline
          terry.tz
          @vtrn_raptor that's high
          • V vtrn_raptor
            F Offline
            F Offline
            @vtrn_raptor so it does start without choke? I can't make sense of what you said mate.
            If it starts from cold without choke then it's 100% too rich
            • terry.tzT terry.tz
              terry.tzT Offline
              terry.tzT Offline
              terry.tz
              @terry-tz that's an easy fix don't worry about that yet
              • F finnerz89
                terry.tzT Offline
                terry.tzT Offline
                terry.tz
                @finnerz89 yes he is bad at describing lol but it seems that way
                • V Offline
                  V Offline
                  vtrn_raptor
                  I forgot to put the , lol and it starts with choke on but I have to take It off to keep it running
                  terry.tzT CalumC 2 Replies Last reply
                  • V vtrn_raptor
                    terry.tzT Offline
                    terry.tzT Offline
                    terry.tz
                    @vtrn_raptor he means will it start cold without choke but don't worry about that
                    • V vtrn_raptor
                      @vtrn_raptor Yeah that's normal mate.
                      It needs choke to start. That's normal. My DT NEVER started without choke.
                      Once it's warm you can take the choke off that's normal.
                      It must be something to do with the stock carb, as I haven't had this issue with my VHSA.
                      But yes, it will need choke to start. Then once its warm it'll go to die, you then take the choke off.
                      What's the problem.
                        What's the problem.
                        terry.tzT Offline
                        terry.tzT Offline
                        terry.tz
                        mine starts with no choke cold every time
                        • V Offline
                          V Offline
                          vtrn_raptor
                          I mean it goes to die before it's warm to keep it going I have to keep the throttle on but anyway just took for a little test ride without the snorkel and was a massive improvement but powervalve still won't kick it it goes to then starts to bog but stays running and it's actually rideable
                          • V vtrn_raptor
                            terry.tzT Offline
                            terry.tzT Offline
                            terry.tz
                            wrote on last edited by terry.tz
                            #53
                            @vtrn_raptor take the cover off the side of the filter
                              terry.tzT Offline
                              terry.tzT Offline
                              terry.tz
                              @terry-tz try hitting the band in second
                              • terry.tzT Offline
                                terry.tzT Offline
                                terry.tz
                                do you have a haynes manual for your bike
                                • V Offline
                                  V Offline
                                  vtrn_raptor
                                  Yeah I have a Haynes mate I would ride it without the cover on but it's raining loads down here lol
                                  terry.tzT 2 Replies Last reply
                                  • V vtrn_raptor
                                    terry.tzT Offline
                                    terry.tzT Offline
                                    terry.tz
                                    @vtrn_raptor haha far enough it would be fine though bit of rain doesn't hurt
                                    • V Offline
                                      V Offline
                                      vtrn_raptor
                                      I'm gunna take the pv cover of and rev it to see if it opens correctly as that could be the issue as was pinned before I got the cdi and put it back on the servo
                                      • V vtrn_raptor
                                        terry.tzT Offline
                                        terry.tzT Offline
                                        terry.tz
                                        @vtrn_raptor go to page 86 and read
                                        • V Offline
                                          V Offline
                                          vtrn_raptor
                                          Will do mate
