  3. Framework
  4. Frames tanks swinging arms forks etc
14 Posts 6 Posters 3.3k Views 1 Watching
  • S Offline
    scrimsmustang
    Hi all, if anyone wants frames tanks swinging arms etc blasting and painting properly i can do them over the winter if you can get them to me. I have the paint code for the DPBM tanks. I have the blaster and paint booth and a bit of time to do it. Its a far better gloss finish on frames than powdercoat. I use 2k on solid colours and basecoat with 2k clearcoat on swinging arms forks etc.
    • DartyD Offline
      DartyD Offline
      Can you do any metal work on the tanks? I'm thinking of dents and rust treatment.
      • S scrimsmustang
        @scrimsmustang do you have a rough quote?
          scrimsmustang
          @darty said in Frames tanks swinging arms forks etc:
          Yes
            scrimsmustang
            @declan said in Frames tanks swinging arms forks etc:
            To do what jobs
            • ricky0115R Offline
              ricky0115R Offline
              ricky0115
              I’m after frame tank and swing arm, any idea how much?
              • ricky0115R ricky0115
                @ricky0115 +1 @scrimsmustang
                • S scrimsmustang
                  NINJAN Offline
                  NINJAN Offline
                  @scrimsmustang What about swing arm polishing? Are you able to offer that service as well dude???
                    @ninja What you mean Ally polishing,
                    There is a companyt in Oxfortd that do it.
                    Around the £80 mark. I was going to get mine done.
                      NINJAN Offline
                      NINJAN Offline
                      @calum COOL yes ali polishing, do you have a link to their webby please???
                        @ninja I think it was these guys
                        http://www.pro-polishers.co.uk/
                        Long time ago now though.
                          NINJAN Offline
                          NINJAN Offline
                          @calum OK thanks bud. :thumbsup_tone5:
                            scrimsmustang
                            I can blast 2k primer and 2K top coat frame, rear footpeg hangers, rear subframe and rear rack for £275 for solid colours like white black red etc £325 for DPBM on an RE frame.
                            I can blast primer basecoat and 2K lacquer swinging arm and dogbones etc, and refinish the forks including sorting out any gouges in them for £125
                            Tanks I can do for £50 if you bare metal them yourself £70 if you want me to bare metal them. Also the DPBM paint is more expensive because its base and lacquer.
                            • S scrimsmustang
                              scrimsmustang
                              @scrimsmustang Just to ad, if anyone does want a frame doing if you have any snapped bolts in the rear were they usually snap get your cobalt drill bits out and drillem out first.
