  3. Framework
  4. Frames tanks swinging arms forks etc
14 Posts 6 Posters 3.7k Views 1 Watching
    Can you do any metal work on the tanks? I'm thinking of dents and rust treatment.
    scrimsmustang
    @darty said in Frames tanks swinging arms forks etc:
    Yes
      @scrimsmustang do you have a rough quote?
      scrimsmustang
      @declan said in Frames tanks swinging arms forks etc:
      To do what jobs
      • ricky0115R
        ricky0115R
        ricky0115
        I’m after frame tank and swing arm, any idea how much?
        • ricky0115R ricky0115
          @ricky0115 +1 @scrimsmustang
          • S scrimsmustang
            Hi all, if anyone wants frames tanks swinging arms etc blasting and painting properly i can do them over the winter if you can get them to me. I have the paint code for the DPBM tanks. I have the blaster and paint booth and a bit of time to do it. Its a far better gloss finish on frames than powdercoat. I use 2k on solid colours and basecoat with 2k clearcoat on swinging arms forks etc.
            @scrimsmustang What about swing arm polishing? Are you able to offer that service as well dude???
              @ninja What you mean Ally polishing,
              There is a companyt in Oxfortd that do it.
              Around the £80 mark. I was going to get mine done.
                @calum COOL yes ali polishing, do you have a link to their webby please???
                  @ninja I think it was these guys
                  http://www.pro-polishers.co.uk/
                  Long time ago now though.
                    @calum OK thanks bud. :thumbsup_tone5:
                      scrimsmustang
                      I can blast 2k primer and 2K top coat frame, rear footpeg hangers, rear subframe and rear rack for £275 for solid colours like white black red etc £325 for DPBM on an RE frame.
                      I can blast primer basecoat and 2K lacquer swinging arm and dogbones etc, and refinish the forks including sorting out any gouges in them for £125
                      Tanks I can do for £50 if you bare metal them yourself £70 if you want me to bare metal them. Also the DPBM paint is more expensive because its base and lacquer.
                      • S scrimsmustang
                        scrimsmustang
                        @scrimsmustang Just to ad, if anyone does want a frame doing if you have any snapped bolts in the rear were they usually snap get your cobalt drill bits out and drillem out first.
