  3. Off Topic
  4. Dt170 vs ktm exc 125
97 Posts 13 Posters 33.1k Views 2 Watching
    @darty snorkel is doing a great job there bud 😂😂
    @declan The snorkel still helps to stabilise air flow, even with a Lanza 230 snorkel, You just cant get enough air through it!
    Airbox is quite restrictive when your tuning these,
    • NINJAN
      I am always confused as to how any air is sucked in with the air box and snorkel system? To me is looks to be pointing in the wrong direction and I always feel that the rider and seat will reduce airflow around that area too. But I guess it is not too restrictive as all bikes perform extremely well with the air box and snorkel set-up. Has anyone tried small air scoops on the side of the air box to draw air into the box at all ???
        @ninja Ahem, RAM AIR.
        Also Aprilia RS125's do this. They take a scoop from the nose cone, and force it into the air box lol.
        But you can get nasty negative air pressure coefficients that cause adverse effects.
        • Glynn123G
          Glynn123G
          Glynn123
          I removed my airbox snorkel and upjetted carb, very good sound and possibly abit more power? Not noticeable mind but does sound brilliant.
            @scrimsmustang don't think it will win over a wr200 but you're right, they are powerful. I Wonder how Honda manages to squeeze out 30 bhp and how Yamaha only ~20 bhp. Seems odd.
            scrimsmustang
            wrote on last edited by scrimsmustang
            #89
            @irongamer727 said in Dt170 vs ktm exc 125:
            CRM will piss over the WR200 ive had a fair few 200,s and the Honda would just laugh at the 200, 125 or not.
            Poo DT200WR compared to CRM
            Poo WR200R compared to CRM
            Mint CRM125R
            • Glynn123G Glynn123
              scrimsmustang
              @glynn123 said in Dt170 vs ktm exc 125:
              Its the mixture screw and pilot jet you need to tweek when you remove the snorkel on a DTR mostly as they bog down at low rpm due to the air rich mixture, dial it out and you get a lot better low down acceleration.
              Glynn123G 1 Reply Last reply
              • D DTR+NSR
                I doubt the crm has a genuine 30bhp. I've got a nsr125 with basically the same engine as the crm. Doesn't 'feel' that much faster than my dtr, wether that's just down to the gearing, as the nsr has alot longer legs.
                scrimsmustang
                @dtr-nsr said in Dt170 vs ktm exc 125:
                Is the NSR derestricted properly ? Should pull atleast 110 derestricted
                • D
                  Yeah, it's a earlier jc20 aswell, which has more aggressive porting than the later jc22 foxeye. Most it's done is just under the ton on the clocks, at the redline in 6th. It's funny cuss in the 125 sports bike world the nsr is regarded as one of the slower bikes. I'd have loved a crm though, just there so thin on the ground.
                  • S scrimsmustang
                    Glynn123G
                    Glynn123G
                    Glynn123
                    @scrimsmustang What pilot jet do you recommend? bike runs great but id say it is slightly lean at idle, slight bog if you flip the throttle back at low revs but isnt bad. Might buy a jet kit for the bike and mess around with a few plug chops this winter.
                    • V
                      V
                      vtrn_raptor
                      Dt would kill a ktm when it come to a straight line
                      • NINJAN
                        Almost;
                        https://www.youtube.com/watch?v=N9TvsCEhfmk
                          Almost;
                          @ninja DT170 though, and still loses lol.
                            @calum Yep 170 vs 144, not too much in it tho. 😉
