  4. 1989 rebuild update
1989 rebuild update
127 Posts 14 Posters 79.0k Views 2 Watching
  • O oldman
    Watched it, still none the wiser, am I thick!
    @oldman ignore him he’s a little simple minded πŸ˜‚πŸ˜‚πŸ˜‚
    • NINJAN
      #22
      @oldman Just a bit of levity. πŸ™‚
      @declan I'm a glass half full kinda guy and it's a pick me up song, 😜
      I know y'all sung along to it, so all together now;
      A one, a two, a one two three four;
      THINGSSSSSSSSSSSS CAN ONLY GET BETTERRRRRRRRRRRRRRRRRRRRRRRRRR !!!
        @ninja think it’s safe to say you don’t have much taste in music πŸ˜‰
          I like the white frame, have considered it myself for another bike πŸ™‚
            @declan No soul dude, DReam was/is a classic !!! πŸ˜‰
              Forks completed with new fork oil, flushed out the RAD but that's pretty sound, few other bits put back together. Wheels gone for rebuild via my mate and hopefully get the loom sorted and fitted over the weekend.0_1512088349588_20171201_001815-1224x1632.jpg
                Proper job that.
                • MiniaM
                  MiniaM
                  Minia
                  Looking good. What colour scheme was this one originally? White'n'red?
                    Originally a white model, have nearly all new panels to go on, will source correct age related graphics if possible, will mostly be original build bar a few user chosen changes.
                      Fitted new steering stem lock and helmet lock, went through the loom and cleaned all connections, fitted to frame and connected everything up, just need to secure and tidy route, rear light fitted as well. Air BOX and battery tray tomorrow and if I have enough time will start to strip carb.0_1512260088018_20171202_235755-1224x1632.jpg
                      0_1512260111214_20171202_235627-1224x1632.jpg 0_1512260126235_20171202_235612-1224x1632.jpg
                      SpannersS 1 Reply Last reply
                        #31
                        0_1512427637235_IMAG0079.jpg 0_1512427665342_IMAG0079.jpg !
                        Care stripped ready for ultrasonic clean and refurb (tomorrow) airbox refitted, brake caliper and master cylinder kits ordered, new front disc (Galfer wavy) ordered, rec counter gasket and washers ordered (missing ), only chain and sprockets left to buy I hope!
                        • O oldman
                          @oldman Care or Carb ??? πŸ˜†
                            It's carb, bloody spell check for you!
                              I thought you were referring to the way you stripped down the card, with care πŸ˜„
                                I always strip with care! Don't want to damage the twins😁 Finished ultrasonic clean and rebuild of the carb with new jets, emulsion tube, air screw (old one seized and spring stuck) drain screw (old one bodged). Any advice on jetting changes (or not?) to suit Romeu exhaust, no other tuning changes made, did fit forged piston though.
                                On to brake rebuilding next.!
                                • O oldman
                                  SpannersS
                                  SpannersS
                                  Spanners
                                  @oldman Did you already have the steering and helmet lock parts or did you source them?
                                  I have recently bought the frame which my bike didn’t have not the steering lock, looking for replacements with keys.
                                  O 1 Reply Last reply
                                  • SpannersS Spanners
                                    @Spanners helmet lock sourced ebay usa and steering lock from ebay germany, steering lock aftermarket but helmet lock genuine, you need metal cover, rivet and conical washer for steering lock, all sourced via Fowlers parts.
                                      So long as you're running 240 main jet you should be fine. With the cold weather you could go 250 and raise the needle slightly to richen the mixture. But I'd say only do that if it were necessary.
                                        Thanks Calum, ordered 240 jet, did put 225 in, will do before fitting to bike, trying to build enthusiasm to go in cold garage!
                                        • O oldman
                                          @oldman well my shed has a wire front so essentially I’m working outside always πŸ˜‰
