The wr200 3xp / dt125r 3bn hybrid 200cc engine no.2
@Louis-James Great little engine your building and like seeing quality work that you do. When i put a 57mm stroke crank in mine didn't fit the washer under the PRIMARY DRIVE GEAR NUT so the so the nut had the maximum amount of threads to screw onto.
The tabbed washer inside the splined washer is used to set the mainshaft endfloat on the clutch on some yamaha engines as they mix and match some gears inside the crankcase.
Was thinking of using this on my new engine build but now decided to see what i can build using the Athena 170 kit so just bought them.
https://www.ebay.co.uk/itm/YAMAHA-WR-200-3XP-4BF-NEW-SLEEVED-BIG-BORE-68mm-Cylinder-PISTON-3XP-11311-00-00/113185389112?hash=item1a5a5ffa38:g:3fwAAOSwEfBbZ3Je@Louis-James where did you get the final drive shaft from as need one for my new build. thanks
@2stroketerry thanks man, I also ran a blaster 200 crankshaft on my original 200cc engine but wasn't happy with less gear meshing between the primary drive and clutch.
With regards to the tab washer.. I can't see it on any exploded diagrams. What years use it?
The final drive shaft I got brand new on eBay from Greece , £30 from memory, from Yamaha it's around £100
Won't the 199cm3 text be an issue at the mot?
@Irongamer727 I have an Athena 170cc kit with a 65mm piston in it that has 124cm3 cast on the side as well as Yamaha 5ML00 on it even though there is no such Yamaha cylinder number so no probelems with mot, police or insurance wise. The cylinder has a base spacer and has been skimmed to the correct compression ratio as well as the exhaust port and powervalve modified being 5mm wider, the transfer ports are raised by 1.5mm. Running the standard tm28 carb with power jet blocked and a 310 main jet it makes maximum power at 11,500 rpm and 37hp. No idea of top speed but running standard 16 57 gearing it goes straight off the clock in 5th gear but clock only goes to 80mph and will rev to maximum revs in 6th gear so it
probably does about 100mph. Was going to gear it up but wheelies mental and when gets to 10,000 rpm it just goes mental with power.
Many MOT testers don't care tbh, but you could file the numbers off or do your big bike test.
I think 2 strokes cc should be measured from above the exhaust port anyway
Finally after 3 suppliers sending the wrong small end bearing... it's on.
Forgot how beasty the piston looks in the 125 cases.
@NINJA it's standard wr200 size (66.80mm)
@Calum no, it's a wr200 crankshaft 57mm stroke
@Louis-James Looking good so far mate, nearly finished my latest engine and will post some photos once finished it. I've gone with a 60mm stroker crank from a blaster and spacer plate to raise the cylinder to suit.
@Louis-James just out of interest how much would you sell a converted engine for providing you could get the parts ?
@stinkwheeler hi, unfortunately I can't offer this as fowlers (my supplier) state that most of the parts I ordered were bottom of the barrel. I could modify the cases for someone who sources Thier own parts.
However this crankshaft here is the same as the dt200r https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F272935562363For anyone who wants a go
@Louis-James
I'm literally waiting for a few nuts and washers to come+ the correct oil pump drive shaft... There's 2 versions.
If anyone has a dt200r , wr200 or dt200wr head spare.. let me know. Rather buy off here..
@Louis-James Honestly that engine is just down right filthy, I just do not know how you have the balls to post pics of an engine is such poor disrepair!!!
:grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy:
But seriously though dude, she looks clinically clean - are you building this on an operating table???
@NINJA well not bad for a 20 odd year old engine
cheers haha -
@Calum not a bad idea
been following your squeaky clean build too -
