  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 154.2k Views 5 Watching
  • Louis-DT-WRL Louis-DT-WR
    @finnerz89 no because I'm only using the new clocks shell. All wires and bulbs I swapped over
    @Louis-James hmmmm 🤔
    • Louis-DT-WRL
      Louis-DT-WRL
      https://youtu.be/La0VeAoF2fU
      • F
        Looking good 👍
          Looking good 👍
          Louis-DT-WRL
          Louis-DT-WRL
          @finnerz89 thanks 🙂 I'll get some more videos outside on a nice day
            Yeah that looks mega!
              Louis-DT-WRL
              Louis-DT-WRL
              @Calum cheers mate.
              Just finishing the final parts.
              Going to inspect the oil pump drive gear to ensure its all ok as the guy before disconnected it.
              The pump leaks from the oil seal. I've stripped, cleaned and ordered a new seal.
              Always the last little things like the brake lights sensitivity etc to finish
              • Louis-DT-WRL
                Louis-DT-WRL
                Need a bit of advice.
                I'm not used to this clutch set up.
                I only removed the clutch cover to fit a new oil pump gear.
                But when I put it back on the Kickstarter wouldn't crank.
                After playing around I got that back into action.
                However there is no tension in the clutch lever.
                I'm not sure it the clutch arm needs a full 360deg rotation.
                I'm not very familiar with this setup.
                The clutch operated fine before and was a new one when I bought the bike.
                Part 11 in this diagram just wobbles around.. but I'm not sure if it's correct.
                https://www.fowlersparts.co.uk/parts/4098902/wr200r-4bf1-1992-999-a/clutch
                  @Louis-James Did you not take any pics before you dismantled it???
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @NINJA I didn't dismantle anything.
                    All I did was removed the casing and replaced the oil pump gear.
                    I didn't touch the clutch.
                      #127
                      @Louis-James Well that's weird, maybe you have just discovered a fault before it ruined all your hard work???
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @NINJA I think I need to remove the clutch arm and rotate it. See what I find tomorrow haha
                        Wish I did it when the engine was out.
                        The water pipe it the biggest pain to fit.
                        • F
                          I had a similar issue on an old bike, the clutch arm operates like a rack and pinion, the arm being the pinion part. I had to engage it further down the rack to get the full range of movement. It's spring loaded, I hope that makes sense lol.
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @finnerz89 it has a stability spring on the arm.
                            But it should be resisted by the 5 clutch springs.
                            Thanks yes it is a rack and pinion type
                              #131
                              @Louis-James These any good to ya???
                              http://mybikemanuals.com/yamaha/yamaha-wr-owners-manuals/
                              https://www.ebay.co.uk/itm/WORKSHOP-MANUAL-YAMAHA-WR200R-/332115601413
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @NINJA thanks for that the link has the manual. Hopefully sort it tomorrow
                                  #133
                                  @Louis-James You're welcome - I'm not sure if they are for your model, as there's quite a few to download online. Just do a search for your model/year and you'll probably find the correct one??? 😉
                                  • D
                                    Is the clutch hub and basket lined up correctly seem to remember you can fit the dt one 4 different ways but will only work in one position
                                    • D DTR+NSR
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @DTR-NSR thanks guys it's all sorted now.
                                      Good thing I checked because the water pump didn't have a gasket in there 😂
                                      This is what happens when other people rebuild
                                        @Louis-James A bullet dodged there dude!!! :thumbs_up_light_skin_tone:
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          @NINJA yes, this engine had a fair few leaks I sorted today
                                          Oil pump
                                          Gear lever seal
                                          Water pump.
                                          Also putting the water pump pipe back in caused many problems, took so many attempts to get it to seal.
                                          But now have a fully functioning to 2stroke pump 😁.. as it was from the factory.
