  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 158.1k Views 5 Watching
    What wattage lamps have you used in the indicators?
    When I changed mine to higher wattage i got the same symptoms you're describing.
    Louis-DT-WRL
    Louis-DT-WRL
    @finnerz89 they're original ones but new
    • Louis-DT-WRL Louis-DT-WR
      @Louis-James Check that the bulbs haven't gone and/or that the loom provides continutity throughout.
        Louis-DT-WRL
        Louis-DT-WRL
        @Calum cheers call, seems a bit of a coincidence that it's both sides
          @Louis-James Just make sure front right is connected to rear right and front left is connected to rear left.
          • F
            If the lamps are standard my money is on the relay. Try disconnecting one and see if you get a flash then.
            Is the switchgear new?
              Louis-DT-WRL
              Louis-DT-WRL
              @finnerz89 does a single flash then stats on.. always the small things take the time haha.
              F 1 Reply Last reply
                @Louis-James another thought, is the light in the clocks led? Try disconnecting that if it is
                -1
                  Yeah, could be your chinese clocks causing problems.
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @finnerz89 no because I'm only using the new clocks shell. All wires and bulbs I swapped over
                      @Louis-James hmmmm 🤔
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        https://youtu.be/La0VeAoF2fU
                        • F
                          Looking good 👍
                            Looking good 👍
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @finnerz89 thanks 🙂 I'll get some more videos outside on a nice day
                              Yeah that looks mega!
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @Calum cheers mate.
                                Just finishing the final parts.
                                Going to inspect the oil pump drive gear to ensure its all ok as the guy before disconnected it.
                                The pump leaks from the oil seal. I've stripped, cleaned and ordered a new seal.
                                Always the last little things like the brake lights sensitivity etc to finish
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  Need a bit of advice.
                                  I'm not used to this clutch set up.
                                  I only removed the clutch cover to fit a new oil pump gear.
                                  But when I put it back on the Kickstarter wouldn't crank.
                                  After playing around I got that back into action.
                                  However there is no tension in the clutch lever.
                                  I'm not sure it the clutch arm needs a full 360deg rotation.
                                  I'm not very familiar with this setup.
                                  The clutch operated fine before and was a new one when I bought the bike.
                                  Part 11 in this diagram just wobbles around.. but I'm not sure if it's correct.
                                  https://www.fowlersparts.co.uk/parts/4098902/wr200r-4bf1-1992-999-a/clutch
                                    @Louis-James Did you not take any pics before you dismantled it???
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @NINJA I didn't dismantle anything.
                                      All I did was removed the casing and replaced the oil pump gear.
                                      I didn't touch the clutch.
                                        #127
                                        @Louis-James Well that's weird, maybe you have just discovered a fault before it ruined all your hard work???
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          @NINJA I think I need to remove the clutch arm and rotate it. See what I find tomorrow haha
                                          Wish I did it when the engine was out.
                                          The water pipe it the biggest pain to fit.
