  4. Most abused dt refurb
112 Posts 10 Posters 52.4k Views 2 Watching
    I don't know if there are cheap alternatives.
    Simply bearings is where I got my bearings £200ish for the lot
      @Calum looks like eBay is the cheap alternative then 50 pound a kit
      O 1 Reply Last reply
        @declan wemoto do a swingarm bearing kit, doesn't include the lower pivot bushes though, check if yours are shot (mine are, spare swing arm though)
        • O oldman
          @oldman swing arm kit off eBay is 26 pound it’s listed as 2004 euro dtr 125 so that’s the same as a 1990 dtr right? It’s just the linkage to worry about I’ll probably try pick up a good condition 2nd gander for cheap, also Haynes states the shocks aren’t serviceable is there still a way to remove the spring?
            Don't think the linkage changed throughout the years
            declanD 2 Replies Last reply
              @Calum I can’t imagine it would
                @Calum are you aware of any dt model codes that end in- o then 0
                  @declan spring can be removed, early model you will probably need spring compressor, later model back off pre-load nuts fully should be able to remove securing ring of top of spring bearing plate and gain free movement of spring to remove lower bearing plate and remove spring, don't lose securing ring of top plate! My early shock bottom mount shot, 1st s/h replacement worse, 2nd one excellent. Spring diameter changes over years.!
                  With spring removed you can check compression damping also
                  • O oldman
                    @oldman so I’m not gonna lose my jaw getting it off lol many thanks I’ll get on that in the next few days
                      Few pictures of some crusty parts
                      https://imgur.com/a/aUUulAe
                      NINJAN O 2 Replies Last reply
                        @declan MMMMMMMMMMMMMMMMMMMMMMMMMMMM Crusty indeed. :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
                          @declan you need to clean your bike more often
                          • O oldman
                            @oldman it’s how I bought it 🤷🏻‍♂️
                              I dunno, seen worse...
                                @declan hopefully you only paid 2 goats and 3 chickens for it??? :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy: 🤣
                                  @NINJA I wished but I play the hands I’m dealt, I’m real struggling with the bolt that connects the linkage with the frame anyone have any tips it’s really stuck in there
                                    @declan Squirt plenty of WD40 on it, let it soak in for a good hour then apply some heat. Use a nice long torque wrench and give it some welly. If that fails then repeat the first steps, then use an impact driver on the stubborn bugger. 😉
                                      @NINJA there’s no way to put a socket or wrench on it I got the nut off and gave the bolt a few whacks but if I hit It anymore it will ruin the bolt
                                        #21
                                        @declan Get some heat on it, then screw the nut on a few turns then hit it from the nut end, that usually does the trick. If you damage the nut that is easier to replace than the bolt. 😉
                                          I put impact driver on bolt end and just kept spinning it and applying wd40, still not easy and takes a while :, leave for a day or two if necessary. Have spare swingarm end bearings soaking in diesel as we speak, Been there 3 days so far!
