  4. Most abused dt refurb
112 Posts 10 Posters 54.2k Views 2 Watching
    @declan Squirt plenty of WD40 on it, let it soak in for a good hour then apply some heat. Use a nice long torque wrench and give it some welly. If that fails then repeat the first steps, then use an impact driver on the stubborn bugger. 😉
    @NINJA there’s no way to put a socket or wrench on it I got the nut off and gave the bolt a few whacks but if I hit It anymore it will ruin the bolt
      #21
      @declan Get some heat on it, then screw the nut on a few turns then hit it from the nut end, that usually does the trick. If you damage the nut that is easier to replace than the bolt. 😉
        I put impact driver on bolt end and just kept spinning it and applying wd40, still not easy and takes a while :, leave for a day or two if necessary. Have spare swingarm end bearings soaking in diesel as we speak, Been there 3 days so far!
        • O oldman
          @oldman how can you get an impact on it? I can’t fit any of my spanner’s or any ratchets it fouls against the frame
            @declan There must be a way, have you consulted the Bible aka the Haynes manual???
              @NINJA yeah it only mentions the ones for the swing arm and dog bones
                Happened on my red one so a while ago, sure I used extension bar and impact driver, rotated bolt and kept lubing, was a right ba@#%&red to get out. You have my sympathy.
                • O oldman
                  So I finally managed to hammer my linkage free I used a soft aluminium washer on the bolt so I didn’t damage it hitting it here’s a few pics of my bushings, thankfully all of my relay bolts are in almost perfect condition and the grease nipples aren’t seized! I cleaned them up real good for the picture
                  https://imgur.com/a/wvOK1wN
                  NINJAN O 2 Replies Last reply
                    @declan That certainly looks corroded for-sure!!! :pouting_face: :pouting_face: :pouting_face:
                    I'm glad that you got the better of the beast tho - good job. :thumbs_up_light_skin_tone: :sign_of_the_horns_light_skin_tone: :call_me_hand_light_skin_tone:
                      @declan you have let those parts go! Thought mine were bad
                      • O oldman
                        #30
                        @oldman again was like that when I bought it I greased them when I got the bike I was using it as an off-road bike so I wasn’t bothered about pitting
                          Just a rough paint so far but you can see what I’m going for https://imgur.com/a/Zw6uzqJ
                            @declan The man with the golden DT???
                              @NINJA it’s got a nice ring to it
                                https://imgur.com/a/OT4SR9R
                                The yoke looks mint irl but it doesn’t show through on the camera it’s a wrinkle black paint which will be my accent paint for the bike and of course it had to be gold rims the gold is the faded vintage colour that I like
                                  @declan You don't see many bikes with gold frames. Yokes look top notch dude, is the paint a rattle can job???
                                  declanD 2 Replies Last reply
                                    #36
                                    @NINJA yeah, powder coating obviously is the best but I enjoy painting, The gold is brushed on and the finish does suffer it’s not perfect but you get to make it more personal touch IMO
                                      Pv was a little mucky
                                      https://imgur.com/a/SLyGEs7
                                        @declan GREASSSSYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY!!!!!
                                          #39
                                          @NINJA , few update pics, still very much a work in progress note the muffler and shock 😉
                                          https://imgur.com/a/N8osube
