  4. Most abused dt refurb
112 Posts 10 Posters 52.4k Views 2 Watching
    Few pictures of some crusty parts
    https://imgur.com/a/aUUulAe
    @declan you need to clean your bike more often
    • O oldman
      @oldman it’s how I bought it 🤷🏻‍♂️
        I dunno, seen worse...
          @declan hopefully you only paid 2 goats and 3 chickens for it??? :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy: 🤣
            @NINJA I wished but I play the hands I’m dealt, I’m real struggling with the bolt that connects the linkage with the frame anyone have any tips it’s really stuck in there
              @declan Squirt plenty of WD40 on it, let it soak in for a good hour then apply some heat. Use a nice long torque wrench and give it some welly. If that fails then repeat the first steps, then use an impact driver on the stubborn bugger. 😉
                @NINJA there’s no way to put a socket or wrench on it I got the nut off and gave the bolt a few whacks but if I hit It anymore it will ruin the bolt
                  #21
                  @declan Get some heat on it, then screw the nut on a few turns then hit it from the nut end, that usually does the trick. If you damage the nut that is easier to replace than the bolt. 😉
                    I put impact driver on bolt end and just kept spinning it and applying wd40, still not easy and takes a while :, leave for a day or two if necessary. Have spare swingarm end bearings soaking in diesel as we speak, Been there 3 days so far!
                    • O oldman
                      @oldman how can you get an impact on it? I can’t fit any of my spanner’s or any ratchets it fouls against the frame
                        @declan There must be a way, have you consulted the Bible aka the Haynes manual???
                          @NINJA yeah it only mentions the ones for the swing arm and dog bones
                            Happened on my red one so a while ago, sure I used extension bar and impact driver, rotated bolt and kept lubing, was a right ba@#%&red to get out. You have my sympathy.
                            • O oldman
                              So I finally managed to hammer my linkage free I used a soft aluminium washer on the bolt so I didn’t damage it hitting it here’s a few pics of my bushings, thankfully all of my relay bolts are in almost perfect condition and the grease nipples aren’t seized! I cleaned them up real good for the picture
                              https://imgur.com/a/wvOK1wN
                              NINJAN O 2 Replies Last reply
                                @declan That certainly looks corroded for-sure!!! :pouting_face: :pouting_face: :pouting_face:
                                I'm glad that you got the better of the beast tho - good job. :thumbs_up_light_skin_tone: :sign_of_the_horns_light_skin_tone: :call_me_hand_light_skin_tone:
                                  @declan you have let those parts go! Thought mine were bad
                                  • O oldman
                                    #30
                                    @oldman again was like that when I bought it I greased them when I got the bike I was using it as an off-road bike so I wasn’t bothered about pitting
                                      Just a rough paint so far but you can see what I’m going for https://imgur.com/a/Zw6uzqJ
                                        @declan The man with the golden DT???
                                          @NINJA it’s got a nice ring to it
