  3. DTRE
  4. Whats a good carburetor for my DT125 with a 170cc athena cylinder kit?
carburetor
28 Posts 7 Posters 13.2k Views 1 Watching
    @claws alt text
    Not to sound boring, but, Keihin PWK 36mm of a KDX220
    Been there done that, mental, makes no sense. Actually slower overall..
    A 32mm can be spot on, if you like to 'hoon' constantly, but these engines are fussy to jet on a bigger carb, I don't recommend it.
    clawsC
    clawsC
    claws
    @Darty cant be slower than now though
    CalumC DartyD 2 Replies Last reply
    • clawsC claws
      @claws You'd be surprised.
      I'm not going into the specifics.
      But Pressure=force/area
      The force is generated via the vacuum of the engine, the area is the size of the carb.
      If the carb increases sizes, but the vacuum remains the same then you will see a drop in pressure. Aka, the pressure to actuate the carb will lower and it may not be as effective, sine the carb works off the venturi effect, getting this balance right is important. Going too big can have adverse affects. Is 36mm too big? I'm not saying that, I'm just saying bigger is not always better.
      clawsC 1 Reply Last reply
        clawsC
        clawsC
        claws
        @Calum of course a bigger carburetor isnt always better but i dont think that i can go slower with the keihin and if i cant get it to run great with the bike i will trade it for a smaller one. but a guy that i know put a 38mm carb in his 1998 dt125r and said that it runs great. still i believe that the new carburetor will out perform the one i have now but if it doesnt i will be a bit disappointed but anyways i wont lose anything with this new carb
          Oh yeah! Report back to us your findings 😃
          • clawsC claws
            wrote on last edited by Darty
            #21
            @claws True, but don't forget you'll make less power under 6-8k Rpm.
            @Calum lol I don't have much to say about these bikes anymore
            clawsC CalumC declanD NINJAN 4 Replies Last reply
              clawsC
              clawsC
              claws
              @Darty doesnt matter. it doesnt have much torque in the lower rpms but its because my ypvs is locked to the up right position. gonna get it resolved as well and maybe get an athena pipe for the bike since its made for the 170cc cylinder kit
              • Glynn123G
                Glynn123G
                Glynn123
                Jetting a none standard carb on a DT is a ballache, 32mm polini pwk didn't make my DT much faster at all without any supporting mods like ignition etc. The fuel usage was well over double too even with both carbs appropriately jetted.
                  @Darty Join the club. But most of us talk about different projects these days.
                    @Darty we kinda miss ya around here
                      @Darty Which bikes are you currently working on/involved with ATM then dude???
                        clawsC
                        clawsC
                        claws
                        @Calum okay so the carb made the dt much better. didnt even have to tune it lol
                        • clawsC
                          clawsC
                          claws
                          and i flipped the bike while doing a wheelie today. bent my front forks and got the rear plastic banged up. getting new ones tomorrow though
