  3. Wheels
  4. SM wheels on 1994 DT125R
31 Posts 7 Posters 7.5k Views 1 Watching
    jonne123
    So if i buy front fork and wheels they should fit?
    • J jonne123
      @jonne123 yeah wr 125x forks fit
        jonne123
        If i make adaptor plate for dt125x brake caliper will the wheels fit in my dtr forks?
        DartyD 1 Reply Last reply
        • J jonne123
          @jonne123 Yes. My current setup exactly.
            jonne123
            So i buy DTX rims, front brake caliper and its adapter. Then its ready to go and does the DTX rims have different speedometer drive so my speedo isnt messed up?
            • J jonne123
              wrote on last edited by Darty
              @jonne123 I believe they are different part numbers yes for the speedo drive, I use a DTX Speedo drive with mine.
              But, beware DTX are waaay better forks, stiffer with less travel in them, they are also shorter than DTR forks which really helps the front end geometry for a Motard setup,
              I have to run 30mm solid bushes in the DTR forks to take out the fork travel and make it somewhat reasonable to ride, otherwise I think it's pretty bad.
              I know WR125R forks are better sprung out the box, and that is a straight swap, you can just run the non mechanical drive WR125R Speedo sensor to the OEM Digital clock, pretty smart setup
              J 1 Reply Last reply
                jonne123
                @Darty So you recommend DTX front fork and DTX wheels. And what else Yamaha parts fit dtr like forks or rims?
                • J jonne123
                  @jonne123 Just get an entire DTX front end bud,
                  • NINJAN
                    As @Darty said, get the complete set-up for less hassle. 😉
                      jonne123
                      #21
                      So is it enough if i buy front forks. Will my yamaha dt 125 r front fork yoge holder fit those?
                        jonne123
                        Can you recommend some good street tires on my enduro rims?
                        • J jonne123
                          @jonne123 Avon Distanzias were a thing back in the day...
                            jonne123
                            Which of these you would recommend?
                            https://mprenkaat-store.com/410-c-760_32_165_532.html
                            • J jonne123
                              @jonne123 I had Avon Trailrider tyres on my DTR and can highly recommend them;
                              https://www.avontyres.com/en-gb/tyres/trailrider?cartype=motorcycle
                                jonne123
                                What is 4.10x18 and 2.75x21 tires in metric?
                                • J jonne123
                                  @jonne123 said in SM wheels on 1994 DT125R:
                                  110x18 and 80x21 are about the same;
                                  You can go up slightly on the stock rims to;
                                  120x18 and 90x21 but that's the limit really.
                                    I'm running 120/80/18 and 90/90/21 Avon road riders on my dt. They are a little pinched up on the narrow dt rims. My plan was to have slightly wider rims laced onto the hubs. Still handles much better than on off road knoblies lol.
                                      jonne123
                                      So i buy avon trailriders or full street tires?
                                      clawsC 1 Reply Last reply
                                        @NINJA They look sweet on that bike to be fair.
                                        • J jonne123
                                          clawsC
                                          clawsC
                                          claws
                                          @jonne123 i think these would be good for the street https://m.motonet.fi/fi/tuote/9821501?ajoneuvo=2371&vuosimalli=1994 https://m.motonet.fi/fi/tuote/9821502?ajoneuvo=2371&vuosimalli=1994
