  4. '99 DT125R "OEM+"
'99 DT125R "OEM+"
37 Posts 8 Posters 17.8k Views 2 Watching
  • Biker_123B
    Biker_123B
    Biker_123
    Good work so far mate! I like what you've done to the bike so far with the subtle changes as to not stray far from the original looks of the bike I respect that 👍🏻.. That heads cleaned up really well what did you use to clean it?
    Every problem has a solution
    BurridgeB 1 Reply Last reply
    • Biker_123B Biker_123
      BurridgeB
      BurridgeB
      Burridge
      @Biker_123 thanks mate, appreciate it 😄 and GT85 and a tooth brush! Works a treat, and a small brass wire brush for the mating face to get the bits of old gasket off
        Right on man, wish mine was as clean as that! Stick in some EBC pads and Steel Braided brake line and you can enjoy the front end a little better,
          BurridgeB
          BurridgeB
          Burridge
          @Darty Cheers I'll give that a go!
            Nice 3MB head. Is in good condition. Should make for a nice upgrade N
            • BurridgeB Burridge
              @Burridge Nice job there man! I have EBC red stuff pads and Wemoto braided lines on my DTR, they do improve the brakes for-sure. I'm going to be adding some Kyoto wavy disks next week, hopefully they will further improve the braking and reduce the stopping distances too!!! ;O)
                BurridgeB
                BurridgeB
                Burridge
                @CYBER-NINJA I'll deffo be ordering some different pads soon, and I'll check out those discs, cheers!:D
                  @Burridge I got mine off ebay;
                  http://www.ebay.co.uk/itm/310817733379?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                  http://www.ebay.co.uk/itm/400596175268?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                  The DT uses the same pads front & rear. ;O)
                  • BurridgeB
                    BurridgeB
                    Burridge
                    Set about fitting the 3MB head today.
                    My torque wrench is too big so went to halfords for one, now if anyone here lies in Derby they'll have heard about the round about in Kingsway that has recently been made larger and now has a load of traffic lights on it. Well long story short, it's fucked everything up and they're shit, the retail park next to said roundabout was completely grid locked. It took about an hour to et out of the retail park once I'd been to halfords. Fabulous.
                    Anyway, £80 later-
                    http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpscclzjq6a.jpeg
                    Then the ball ache commenced:
                    http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsp8wdnkgg.jpeg
                    Old 3BN head off:
                    http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpspbkvmfas.jpeg
                    Nice clean 3MB head on and all put back together, with genuine yam head gasket.
                    http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsiqzqopgs.jpeg
                    Started about 4th kick, took for a ride and can tell it's got more compression, it vibrates more too and seems abit nippier, will be better when I get my new zaust.
                    Unfortunately the sender wotsit in the head for the temp gauge looks completely different to the one in my 3BN head, hoped it would work but it doesn't.. Stayed at cold the whole time I was out. So I'll need a new one of them:(
                    • BurridgeB
                      BurridgeB
                      Burridge
                      Hopefully I don't get the ban hammer for posting pornographic material but I'll take the risk.
                      Postie brought this today 😄
                      http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsxkt6nr0i.jpeg
                        Yeah that's a work of art!
                        • BurridgeB
                          BurridgeB
                          Burridge
                          Unfortunately it turns out not to be the best of fits.
                          Got it on tonight and will need to shorten the end by an inch or more to get my dep can on, it's an uncomfortable amount too close to the frame and touches the top of the bracket where the standard pipe bolts on, and I'll have to find a spacer for the bracket on the pipe that mounts to the frame, as there's a hefty gap between the pipe and where it's supposed to mount to, and I'm not about to rip the bolts off the head torquing it down!
                          http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsehcoay8y.jpeg
                          http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsrrqtr9zh.jpeg
                          • BurridgeB
                            BurridgeB
                            Burridge
                            It looks fairly badass though, I'll hopefully have resolved the fitting issues by tomorrow.
                            http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsloxamlgu.jpeg
                              I wouldn't bother with the frame bolt. I never did on the dep pip anyway. The pipe os so light that just the end can connected to the frame will be enough!
                              • MightymanM
                                This was the trouble I found with getting one of his pipes. I asked for a twin pipe to fit the DTX, and what he sent me was made to fit the DTR, and although the frames should be the same, I had to adjust two of the mounting holes to get mine to fit. Even then, it didn't look completely straight. He does great work don't get me wrong, but I paid so much for it and to have it not perfectly fit was very frustrating.
                                • AndyYamA
                                  AndyYamA
                                  AndyYam
                                  1st off, great thread.
                                  with regards to the exhaust im sure there is a slight difference between the 88-96 and 96-04 frames or at least the brackets. i remember swapping them over and they just didnt line up the same.
                                  • BurridgeB
                                    BurridgeB
                                    Burridge
                                    Well guys I've managed to get it on, all be it big faff. Haven't bothered with the bracket as Calum's said, cut an inch and a half off the end and got the dep on, the 2 pipes were so far out they were almost side by side. Put a spacer on the front bracket of the dep to pull it out more to like up abit better with the main pipe, used the original grommet with a piece of handle bar grip packing out the main pipe cus it was far too big.
                                    Next problem!!
                                    The pissing front midguard hits the pipe when turning the bars left! For now I'm gonna pack out the 2 bolts holding it on
                                    closest to the engine to angle it away from the pipe, and maybe get a different midguard later on that I can butcher abit to fit round the pipe.
                                    @mightyman I know how you feel, this thing wasn't cheap and as good as the workmanship is I've been pretty pissed at how badly it fits, with the equipment the guy has to make these things and how much he's making off them I'd have thought he'd have some decent jigs to make sure they fit better than they do. It said in the title that this was for a dt125 r
                                      Next problem!!
                                      @Burridge Nah must admit thats not on really!
                                      Fingers crossed though that the performance is at least decent!
                                        BurridgeB
                                        BurridgeB
                                        Burridge
                                        @Calum said in '99 DT125R "OEM+":
                                        Shut up it is!!! Hahaha
                                        Sorted the midguard problem out, a nut between the top of it and the bottom of the yokes gave enough clearance and it looks no different so I'll be leaving it like that. Everything tightened up I took it out and the faff has been worth it. It's transformed it completely, power kicks in at 6000 from the pv opening then at 8000 the pipe kicks in with a nice rasp, and goes on to go off the clock at 80mph 😄
                                        Next problem: melted my boot on it.
                                        • BurridgeB
                                          BurridgeB
                                          Burridge
                                          What do do next I wonder...
                                          http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsul4azmld.jpeg
