  4. '99 DT125R "OEM+"
'99 DT125R "OEM+"
37 Posts 8 Posters 17.8k Views 2 Watching
    @Burridge Nice job there man! I have EBC red stuff pads and Wemoto braided lines on my DTR, they do improve the brakes for-sure. I'm going to be adding some Kyoto wavy disks next week, hopefully they will further improve the braking and reduce the stopping distances too!!! ;O)
    BurridgeB
    BurridgeB
    Burridge
    @CYBER-NINJA I'll deffo be ordering some different pads soon, and I'll check out those discs, cheers!:D
    • BurridgeB Burridge
      @Burridge I got mine off ebay;
      http://www.ebay.co.uk/itm/310817733379?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      http://www.ebay.co.uk/itm/400596175268?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      The DT uses the same pads front & rear. ;O)
      • BurridgeB
        BurridgeB
        Burridge
        Set about fitting the 3MB head today.
        My torque wrench is too big so went to halfords for one, now if anyone here lies in Derby they'll have heard about the round about in Kingsway that has recently been made larger and now has a load of traffic lights on it. Well long story short, it's fucked everything up and they're shit, the retail park next to said roundabout was completely grid locked. It took about an hour to et out of the retail park once I'd been to halfords. Fabulous.
        Anyway, £80 later-
        http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpscclzjq6a.jpeg
        Then the ball ache commenced:
        http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsp8wdnkgg.jpeg
        Old 3BN head off:
        http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpspbkvmfas.jpeg
        Nice clean 3MB head on and all put back together, with genuine yam head gasket.
        http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsiqzqopgs.jpeg
        Started about 4th kick, took for a ride and can tell it's got more compression, it vibrates more too and seems abit nippier, will be better when I get my new zaust.
        Unfortunately the sender wotsit in the head for the temp gauge looks completely different to the one in my 3BN head, hoped it would work but it doesn't.. Stayed at cold the whole time I was out. So I'll need a new one of them:(
        • BurridgeB
          BurridgeB
          Burridge
          Hopefully I don't get the ban hammer for posting pornographic material but I'll take the risk.
          Postie brought this today 😄
          http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsxkt6nr0i.jpeg
            Yeah that's a work of art!
            • BurridgeB
              BurridgeB
              Burridge
              Unfortunately it turns out not to be the best of fits.
              Got it on tonight and will need to shorten the end by an inch or more to get my dep can on, it's an uncomfortable amount too close to the frame and touches the top of the bracket where the standard pipe bolts on, and I'll have to find a spacer for the bracket on the pipe that mounts to the frame, as there's a hefty gap between the pipe and where it's supposed to mount to, and I'm not about to rip the bolts off the head torquing it down!
              http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsehcoay8y.jpeg
              http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsrrqtr9zh.jpeg
              • BurridgeB
                BurridgeB
                Burridge
                It looks fairly badass though, I'll hopefully have resolved the fitting issues by tomorrow.
                http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsloxamlgu.jpeg
                  I wouldn't bother with the frame bolt. I never did on the dep pip anyway. The pipe os so light that just the end can connected to the frame will be enough!
                  • MightymanM
                    This was the trouble I found with getting one of his pipes. I asked for a twin pipe to fit the DTX, and what he sent me was made to fit the DTR, and although the frames should be the same, I had to adjust two of the mounting holes to get mine to fit. Even then, it didn't look completely straight. He does great work don't get me wrong, but I paid so much for it and to have it not perfectly fit was very frustrating.
                    • AndyYamA
                      AndyYamA
                      AndyYam
                      1st off, great thread.
                      with regards to the exhaust im sure there is a slight difference between the 88-96 and 96-04 frames or at least the brackets. i remember swapping them over and they just didnt line up the same.
                      • BurridgeB
                        BurridgeB
                        Burridge
                        Well guys I've managed to get it on, all be it big faff. Haven't bothered with the bracket as Calum's said, cut an inch and a half off the end and got the dep on, the 2 pipes were so far out they were almost side by side. Put a spacer on the front bracket of the dep to pull it out more to like up abit better with the main pipe, used the original grommet with a piece of handle bar grip packing out the main pipe cus it was far too big.
                        Next problem!!
                        The pissing front midguard hits the pipe when turning the bars left! For now I'm gonna pack out the 2 bolts holding it on
                        closest to the engine to angle it away from the pipe, and maybe get a different midguard later on that I can butcher abit to fit round the pipe.
                        @mightyman I know how you feel, this thing wasn't cheap and as good as the workmanship is I've been pretty pissed at how badly it fits, with the equipment the guy has to make these things and how much he's making off them I'd have thought he'd have some decent jigs to make sure they fit better than they do. It said in the title that this was for a dt125 r
                          Next problem!!
                          @Burridge Nah must admit thats not on really!
                          Fingers crossed though that the performance is at least decent!
                          BurridgeB 1 Reply Last reply
                            BurridgeB
                            BurridgeB
                            Burridge
                            @Calum said in '99 DT125R "OEM+":
                            Shut up it is!!! Hahaha
                            Sorted the midguard problem out, a nut between the top of it and the bottom of the yokes gave enough clearance and it looks no different so I'll be leaving it like that. Everything tightened up I took it out and the faff has been worth it. It's transformed it completely, power kicks in at 6000 from the pv opening then at 8000 the pipe kicks in with a nice rasp, and goes on to go off the clock at 80mph 😄
                            Next problem: melted my boot on it.
                            • BurridgeB
                              BurridgeB
                              Burridge
                              What do do next I wonder...
                              http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsul4azmld.jpeg
                                @Burridge said in '99 DT125R "OEM+":
                                Savage 🙂 worth the pain mate!
                                  @Burridge it's crying out for a USD conversion! i
                                  • BurridgeB
                                    BurridgeB
                                    Burridge
                                    Not much of an update but gave it abit of tlc the other day.
                                    I must say, if you've had trouble finding products that do what you want to add some good shine, Auto Glym works wonders.
                                    I used Auto Glym rapid detailer on the plastics and tank (their super resin polish didn't touch it, but this spray makes it like new) and their trim gel on things such as air box, clocks, fork gaiters and brake disc cover brings all up really well.
                                    http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpso3xfzmr0.jpeg
                                    The only other mods I really have on my list for this bike are a zeeltronic ignition and possibly a WR200 swing arm if I can find one that isn't in fkin Australia or somewhere stupid.
                                    • BurridgeB
                                      BurridgeB
                                      Burridge
                                      Got this today, it's pretty mint too which is nice :p.
                                      http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsfnji3fgv.jpeg
                                      http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsmsmwcvcq.jpeg
                                      http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsxuvzmfdk.jpeg
                                        @Burridge OEM+ Indeed
                                          BurridgeB
                                          BurridgeB
                                          Burridge
                                          @Calum Yes sir 😜
